New truck problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerNoob, Nov 15, 2016.
  1. truckerNoob
    truckerNoob Bobtail Member
    9
    Dec 9, 2015
    First, the first rotation on startup of my C15 Acert is hard, like it almost doesn't want to start. Getting past that first rotation it starts right up. I tested the CCA on each battery. They are rated for 950 CCA and 3 of the 4 tested at that. The other was just over 700. Does this sound like a battery problem or something else?
    Second, the engine had a gold kit put in 8000 miles ago. If the engine isn't warmed up to 160 degrees it stumbles on acceleration onto the highway and blows a grey smoke. After 160 degrees it runs great. Any ideas on this?
    Thanks
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Mine was doing that on my N 14. Replaced the starter and now it cranks fast and starts right up.
    Duckman1005, truckerNoob and ShooterK2 Thank this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Look at oil, see if it is a weird color. Are you having to add coolant? That hard start kinda sounds like you have coolant leaking into a cylinder and trying to hydro lock. That smoke you mentioned is the coolant burning off. Since you just had an inframe done I bet you have a headgasket failing from improper liner height or a bad head. Cat heads have been having issues with the reman and castings. Another thing it might be is a starter getting weak. Hope for the later but I betting not.if it is coolant get it fixed pronto. You can bend a rod trying to start it with coolant sitting on a piston.
    cnsper, x1Heavy, Oxbow and 5 others Thank this.
  5. Duckman1005
    Duckman1005 Bobtail Member
    28
    21
    Nov 18, 2015
  6. wore out
    wore out Numbered Classic
    17,230
    213,248
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The answer lies in the smoke
    Grubby, cnsper, x1Heavy and 5 others Thank this.
  7. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Starter won't make the engine smoke and studder.
    wore out Thanks this.
  8. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Guys I think the second question of his is that the engine is in cold mode. Correct me if I'm wrong, but my acert will smoke and stumble if I don't let it get warmed up properly once I hit the road in the morning. It won't do it all the time but sometimes it will even cut my turbo boost in half till warmed up too. Once up to operating temp it runs great.
    Did you check and clean all the connections? Is it possible whoever did overhaul didn't get something hooked up right or is loose?
    truckerNoob Thanks this.
  9. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Take the gueswork out off this story and take oilsample.
    Have it analysed.
    Simple.
  10. Duckman1005
    28
    21
    Nov 18, 2015
    Talking about the rough starting part of his problem Einstein...
  11. truckerNoob
    9
    Dec 9, 2015
    Oil looks ok to the eye, sending a sample to OCS (have their bypass system). I did the water bottle bubble test to check the head gasket and I had no bubbles. Oil and coolant levels are staying steady. I'll do some more checking while i wait on oil sample. And I'll test the starter.
