no distance
Discussion in 'CB Radio Forum' started by koncrete cowboy, Mar 22, 2014.
  1. koncrete cowboy
    koncrete cowboy Medium Load Member
    638
    331
    Jun 11, 2013
    Pennsylvania
    2011 prostar
    Two antennas
    29ltd classic.....turned up
    Here s my problem....I can see you coming towards me talking to me on the cb..may be 3/10 of a mile away..I can barley hear you.
    As you pass sounds great...but when your by me your gone 20 seconds...I have no range
    I changed my antennas. ..((stock))...even tried another radio...same problem...should I change coax?
    The only way it even works close to bearable is to turn the squelch all the way down and turn the dynomike up.
    Two shops looked at the radio said its fine...but no one wants to come out of there hut and look at the truck
    Any ideas?
  3. BigBearNY
    BigBearNY Light Load Member
    160
    37
    Mar 14, 2014
    YES!!! I would change the coax. Make positive sure you have the correct type (IE 50 ohms single, 75 ohms dual). Other possibilities include:
    Poor antenna placement... getting blocked.
    Did you use the same mic? If it's got a short and sets are electronically switched this could be an issue.
    Have you checked your SWR on transmit? High SWR can indicate a bad coax. It's a reach BUT back in the day if someone wanted to give you headaches, they might "pin" your coax. This involved pushing a straight pin through your coax and cutting off the ends. Causes all sorts of problems. Shorts shield to center wire. I think antenna placement is the most likely. Can your temporarily borrow a magnetic mount? Place it as high as possible and away from metal that would block signal. If you suddenly grow ears, reposition the antenna.
    koncrete cowboy Thanks this.
  4. burnsey
    burnsey Light Load Member
    81
    40
    Jan 24, 2014
    seacoast, NH
    I second the coax! Another thing to check, I recently encountered a problem similiar to you and it turned out the antenna mounting stud was shorted between the antenna mast and ground. Oddly enough the SWR wasn't through the roof. My guess is your coax has a break somewhere in the center conductor.
  5. Ridgeline
    22,718
    123,152
    I would get good coax, ditch one antenna and stick to just one.
  6. koncrete cowboy
    638
    331
    Jun 11, 2013
    Pennsylvania
    Mind me asking why as to the ditching one antenna? ...is not two better than one....like girls..lol....:)....thanks
  7. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    One is better get a good coax like the mini 8 and check your swrs make sure you have a good ground if yoyr swrs are high say 3to1 on all channels you have a ground problem.
  8. Picklechips
    Picklechips Light Load Member
    103
    34
    Feb 23, 2014
    Turn your SQL all the way to the left. Turn the RF gain all the way to the right and let the static rain. A lot of people adjust these so they hear no noise problem is you cut out a lot of signals and they wonder why they can't hear. Trust me you will get use to the noise and you will like your radio a lot more.
  9. Mjgonehunting
    Mjgonehunting Bobtail Member
    11
    Mar 24, 2014
    NY
    My impression from talking to radio techs is that 2 antennas can be too close together,and actually sort of fight each other!
    i run Gallaxy 88 with a single Wilson 2000 and have good results .
    sometimes it can be atmospheric conditions that cause problems,not your radio!
    i had issues one time with mine,where a guy a few miles away lost me,but I talked to a guy 2000 miles away on skip a few minutes later and he heard me fine!
    a few days later it was fine with no adjustments!
  10. BigBearNY
    160
    37
    Mar 14, 2014
    They really don't fight each other but the accepted minimum distance between dual antennas is 8 feet. Less than that will see no gain over a single. and remember your gain, if properly spaced is only front and back. Sometimes, depending on setup, you may lose a little bit side to side. Many years ago I had two Shakespeare Big Sticks co-phased on the roof of my house. Set apart about 16 feet. Worked great. I had thought of mounting on a boom, with a cheap rotor for a beam but never got around to it.
  11. kc0iv
    kc0iv Light Load Member
    294
    233
    Mar 31, 2010
    Parkville, Mo
    The reason for the 8' has to do with the phasing of the two antennas. Change the phase and different spacing will work. Many commercial antennas use less spacing. A good example is AM broadcasting antennas most of them use spacing much less than a 1/4 wavelength.
    leon
