No Heat Control
Discussion in 'Western Star Forum' started by jagla, Sep 11, 2018.
  1. jagla
    jagla Bobtail Member
    6
    I have a 1998 4964FX Western Star and the temperature control doesn’t work. This truck doesn’t have the knobs to turn but has the slider that goes left and right. The temp slider is connected to what looks like a reostat that has 2 wires attached to it. There is no valve on the heater hoses, they go directly from the engine to the heater core. Does anyone know how this system is supposed to work? I’m only familiar with the systems that use a cable to turn on and off a valve in the heater hose to regulate temp.
  3. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Trace both heater hoses. Make sure you don’t have the valve inline. Next is to contact the dealer and get a parts diagram of the heating system. That will show you where the valve goes, if you have one.
  4. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    It controlled by electric selinoid valve should be right near bunk heater same w cab look at bunk first easier to get. Should have a heater control valve . I’m sure you have the shutoffvalves turned on total 4 . Otherwise that’s how it works cable or electric heater control valve somewhere in lines If they were hooked straight it would be hot always check shutoff valves under hood first
  5. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    I had a 92 Star Cab heater valve was on firewall( under hood) passenger side. Valve was air over electric type. It has an electrical and a 1/4” air line connection.Same thing under bunk. I think they were used up until 2000. If Valve goes bad it sometimes puts 100 psi into coolant causing many a head gasket or overhaul misdiagnosis.Very elusive as it only puts air into coolant once thermostat is satisfied and valve closes.
