No power to AC compressor
Discussion in 'Peterbilt Forum' started by zircon, Jul 2, 2011.
  1. zircon
    zircon Bobtail Member
    23
    5
    Mar 12, 2010
    Austin Texas
    2000 Peterbilt 379. No power to AC compressor. Power is at switch on dashboard, but can't trace power past switch. What wires from switch take power to the compressor. Pressure switches appear to be closed. What terminals on AC switch are hot when switch is closed? Thanks for any info.
  3. SL3406
    SL3406 Medium Load Member
    551
    1,502
    Jan 10, 2011
    Oklahoma
    Power for the compressor clutch comes from the relay in the fuse panel. The pressure switches are on a ground circuit. You can unplug the wire and jump across with a paper clip to test if the pressure switches are closed.
    zircon Thanks this.
  4. zircon
    23
    5
    Mar 12, 2010
    Austin Texas
    Thanks, SL3406. Had actually checked that already,and that's not the problem. Thanks for the suggestion though. Appreciate your input. I'll keep working on it.
  5. texas rattler
    texas rattler Light Load Member
    76
    13
    Aug 7, 2011
    cat spring texas
    if the relay is good i would look for a thermostatic switch on the evaporator box,typical a/c systems will use this to control compressor.im assuming the pete has one.it has to have some way to signal the comp. as you move the lever from say vent to a/c. good luck
  6. AZ379PETE
    AZ379PETE Bobtail Member
    5
    Had same problem it was in my, ignition.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    http://www.supermiller.com/pdf/sk25762.pdf
    This should a schematic for your 2001. Looks like the A/C clutch is wire 93 that goes right to the relay. All other switches turn the relay on/off, so the first thing I'd do is make sure the relay has power and then jump to top make sure the clutch comes on. If it does, the wiring to the clutch is good. Then you have a bad relay or wiring on the other side of the relay. If it doesn't, you have a problem with the wiring to the clutch.
    QUALITYTRUCK Thanks this.
