The wire to the reverse lights goes from the lights into the cab, doesn't stop anywhere along the way. I can apply +12V to that wire at the cab and lights come on. So, no break in the wire. Someone, just going off of documentation, told me they're run by a chassis node mounted on the chassis, which is run by a CECU. But I see no chassis node anywhere under the truck. I checked another Pete 337 and that one doesn't appear to have this chassis node neither. Supposedly, this is how 2010+ is supposed to work (CECU + chassis node). Anyway, the wire goes into a large harness behind the steering column and gets lost from there.
Does anyone have a wiring diagram they can share? If I could just find out where that wire originates, wehre that item is located... Relay? TCM? Chassis node?
No reverse light 2011 Peterbilt 337, Allison automatic trans
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by moocowman, Oct 16, 2020.
