No start no dash lights
Discussion in 'International Forum' started by Juju83, Oct 27, 2022.
  1. Juju83
    Juju83 Bobtail Member
    8
    Oct 25, 2022
    went to go ahead out this morning cranked my truck up put it in gear turned on my wipers and truck died no lights on dash board won't turn over won't do nothing please someone help me
  3. D.Tibbitt
    157,032
    Does it crank or anything ? Or is there no response from anything when key is turned on?
  4. kwswan
    kwswan Road Train Member
    2,028
    11,077
    Jul 26, 2009
    mcminnville,tn.
    Have you checked the obvious things like the battery cables and connections?
  5. Juju83
    8
    Oct 25, 2022
    Yes check batteries checked wires starter and nothing someone said maybe the alternator there's no response at all when key is on
  6. D.Tibbitt
    157,032
    Check fuse box for blown fuses... if you turned it on and started the truck and was running fine until u turned on the wipers.. It sound like wiper motor shorted out into something and blew power somewhere that took out everything else... what is model and year of truck?
  7. Juju83
    8
    Oct 25, 2022
    2015 international prostar I checked fuses it seems like I am not getting any power to the starter or anything from the batteries
    D.Tibbitt Thanks this.
  8. Juju83
    8
    Oct 25, 2022
  9. D.Tibbitt
    157,032
    Do u have a Volt meter ? Take voltage reading at batteries and at starter.
    Cattleman84 Thanks this.
  10. Juju83
    8
    Oct 25, 2022
    I don't have a voltage meter
  11. D.Tibbitt
    157,032
    you are going to need to test your voltage to see where your power is going.
