NO START
Discussion in 'Volvo Forum' started by dcwjr, Oct 9, 2014.
  1. dcwjr
    dcwjr Light Load Member
    58
    Jan 11, 2013
    08 volvo vnl d13 cranks and no start, have sid 1-6 and fmi 5, all 6 injectors with voltage issues, anyone see this issue before-
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be bad wiring, connection (becouse of oil leak from harness sealing to ecm connecor)
    sometimes damaged with oil voltage converter inside ECM. Usually trasnformer goes bad
    first of all remove valve cover and check wiring for damage, check circuirs of every injector to ecm
    check injector coils for short circuit.
    if wiring and injectors are ok, look for used ECM.
    If u see oil in wirng harness - replace injector wiring with new (including seal)
  4. Numb
    Numb Crusty Curmudgeon
    4,284
    10,149
    Jan 30, 2012
    Charlotte, N.Carolina
    need the FMI ,PID ,MID, numbers.
    MID 128 is engine
    SID 1thru 6 injectors
    FMI 5 is low voltage value.
    short in harness or fuel injector solenoid.
    E
