No wait to start light, No starter activation.
Discussion in 'International Forum' started by newtowing, Jan 20, 2015.
  1. newtowing
    newtowing Bobtail Member
    Washed my 07 International 4300 DT466. Drove 10 min. to home base and parked, next morning Wait to start light came on during gauge check then remained off, starter would not crank with key, jumped contacts, starter works. Checked all fuses, breakers, in cab and on left front fenderwell, swappped out starter relay, checked three fusible links near engine compartment fuse box, battery box fuses and links checked:biggrin_2552: out. Don't know where to look anymore.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    The engine ECM actually allows the starter to crank if it is properly booted up. When you turn on the key do you get the yellow CHECK engine light and red STOP engine coming on for a bulb check? Also, if this has an automatic transmission the transmission TCU also has to be properly powered up and happy to allow the engine to crank. Did you check the starter relay along the harness near the firewall, or the solenoid on the starter itself?
  4. newtowing
    The only light that does not illuminate during lamp check is the yellow service light. Are you refering to starter relay in the under hood fuse box?
  5. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    When you say you washed it what did you wash? Just the truck or the engine too?
    If you washed the engine most likely you have water in your sensors, and electrical connectors, causing sending a fault signal to the ECM. Dry out the connectors blow it with air,or use electric contact spray.
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    If you the plastic power distribution box with some relays and fuses, yes, that is the one.
  7. newtowing
    Engine too. Pulled all plugs cleaned with electo contact cleaner dryed and coated with dielectric grease on every connector I could find. also all power and ground posts. No change, Am thinkin ECM fried.
  8. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I would have it towed to an International dealer before throwing an expensive and non-returnable ECM on it.
  9. wvsavage
    wvsavage Bobtail Member
    I have a 2006 Int. 7400 with a DT466 in it and my starter done the same thing and come to find out after replacing my starter it was my ignition switch all the time so I have to pick it up and replace it
