noise
Discussion in 'Ask An Owner Operator' started by Condi, Jul 18, 2019.
  1. Condi
    Condi Light Load Member
    124
    130
    Sep 9, 2012
    Hi,
    In the last few days my 2014 cascadia developed a noise. It sounds like tires when you roll the window down but much louder. It starts at 55 mph and gets weaker faster i go. I can hear it more when with a trailer or under load. More likely coming from the back but not sure. When cruising and giving it more gas the noise gets louder. Moment i get my foot off the pedal it gets weaker. Under 55 i barely notice it. Truck has 400k miles on it and i am pulling tanker. Any ideas please. Thanks
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    this makes no sense, please re-read..
    1) It sounds like tires when you roll the window down but much louder. It starts at 55 mph and gets weaker faster i go.
    2) When cruising and giving it more gas the noise gets louder.
    you first say it gets weaker the faster you go, then you say it gets louder the faster you go....can't have it both ways.
    Milr72 Thanks this.
  4. Condi
    124
    130
    Sep 9, 2012
    Lets say i go 60 on flat. The moment i press gas and create more torque it gets louder. Its louder under torque
  5. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    My best guess would be turbocharger.
    Condi Thanks this.
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Any vibrations, rattling or humming?
    Condi Thanks this.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Forgive me if this seems like a stupid question, but it has to be asked. Is your engine fan stuck on?
    Condi, JoeyJunk and 86scotty Thank this.
  8. 86scotty
    86scotty Road Train Member
    4,672
    12,806
    Aug 27, 2017
    Appalachia
    Or exhaust/flex pipe leak.
    Condi and mitrucker Thank this.
  9. Condi
    124
    130
    Sep 9, 2012
    Yes, before this noise started i had vibrations once in a while and only with some tandem trailers and only between 34-50 mph! I thought this was the trailer problem. This noise that i hear is a humming noise. Low frequency hum
  10. Condi
    124
    130
    Sep 9, 2012
    Engine fan starts and stops like it normally does
    RustyBolt Thanks this.
  11. Condi
    124
    130
    Sep 9, 2012
    So i shut engine off while driving and noise is still there. But its so weak that i am not sure. There is tires hum and something else on the background.
