Observations from roadside inspections
Discussion in 'Trucking Industry Regulations' started by Mike_MD, Sep 12, 2009.
  1. Mike_MD
    Mike_MD Medium Load Member
    352
    240
    Feb 4, 2009
    O-Zone
    I must perform 32 Level I or Level V inspections to remain qualified for my position, the federal government’s fiscal year ends 09/30/2009 and my inspections must be performed this month as I neglected to complete them earlier. I will say the last minute completion was not lack of foresight but a last minute change of heart. I am getting old and at times feel my age times ten, roadside inspections is one such time as it is physical work that I’m not accustomed to; combined with knee, back, and ankle ailments it was miserable doing the inspections. In 2008 I provided sufficient medical proof that I should be excluded from the requirement to perform 32 inspections and was excused from the requirement. I take it to heart that I am not performing my job 100% and on 03/27/2009 I went on a weight loss regime and managed to drop 45 pounds; I went from 275 to 230. My ultimate goal is at least 200 maybe 180 if I can stay motivated. With the weight loss and exercise routine I felt better and decided to complete the required inspections. My first day it was tough and I completed three inspections before calling it a day, the next day I managed four, then five, then seven. With each day I became more accustomed to performing the work and felt better at the end of the day; tired but better. It’s still hard work to squeeze under the truck to inspect the frame, brakes, and everything else but it’s a necessary evil and I understand the importance of performing the task. With that said….
    On 09/10 and 09/11 I placed 6 of 12 vehicles inspected OOS, some were minor things such as neglecting to lock down all four corners of the intermodal container but others were significant, i.e. loose bolts on the fifth wheel and inoperable tractor protection valve. Several vehicles had three to five brakes out-of-adjustment.
    My last inspection of the day on 09/11/2009 involved a knowledgeable young man that recognized the steps I was taking to check the tractor protection valve and even commented that the check was part of the driver pre-trip for the CDL. I was disappointed placing the vehicle OOS for one of five loose fifth wheel bolts on the left side and inoperable tractor protection valve; the fact the vehicle had a CVSA sticker from July 2009 and an annual inspection a few days earlier was equally disappointing.
    For those of you in Illinois that use the Illinois Safety Lanes, be advised if the “Pass”/”Fail” portion of the form is not completed it does not count as a periodic inspection. When you read the back of the form where the inspector signs there is a disclaimer; “when applicable”; the State of Illinois requires a safety lane inspection every six months for intrastate carriers. If a vehicle has a US DOT number the carrier is excluded from the requirement of having to obtain an Illinois Safety Lane inspection every six months; however, the vehicle must have an annual periodic inspection. The safety lane inspection may count as a periodic inspection; however, the form must have the items inspected marked as pass or fail; without the front of the form being completed the inspection is not a periodic inspection. Before some cry foul, many of the safety lane inspections are completed in 15 minutes or less, I’ve seen some in as little as seven minutes. Not a very thorough inspection in my opinion. Some of the safety lanes use a brake differential testing device. The brake tester has a hydrometer with two pads; as long as the hydrometer doesn’t show a difference then the brakes pass…. My question, what if both brakes are inoperable how would the machine know the brakes were inoperable?
    IMHO many garages fail to perform a proper periodic inspection and there are probably some roadside inspectors that neglect to perform a proper North American Standard Truck Inspection creating a potential situation where the vehicle maybe placed OOS at a later date for violations not discovered earlier. I am not perfect and I know there are things I miss as well; however, I do try to do my best. I encourage people to get more involved in the vehicle inspection process. It’s better to discover the violation yourself than be placed OOS for things later. There is nothing that prevents a person from performing their own periodic inspections and doing the work provided they meet some fundamental requirements:
    If a person can meet the requirements specified they can perform their own repairs and periodic inspections.
    It should be noted that vehicles with clamp style brakes out-of-adjustment now receive two violations:
    §393.47(e) and §393.53
    If the brakes out-of-adjustment is 20% or more, i.e. 2 of 10 or 1 of 4, or 1 of 5, a third violation of §396.3AB is added to place the vehicle OOS.
    A little history on the issues surrounding automatic slack adjusters, the NTSB has been very vocal in the FMCSA mandating that if brakes equipped with automatic slack adjusters are out-of-adjustment then the slack adjuster has failed and should be replaced. The link should help folks better understand the reasoning for the recent changes regarding brakes out-of-adjustment and slack adjuster violations: http://www.ntsb.gov/Events/journalist/lessons/LL_truck_air_brake.txt
    It is important for motor carriers to be more conscious of their roadside inspection history as CSA2010 is scheduled to take affect July 2010. The program has been in the developmental stages since 2007 with several states piloting the program to tweak it to perfection. CSA2010 is short for Comprehensive Safety Analysis 2010. The program will use the carrier’s roadside inspection information to establish the carrier’s ability to continue operation. You can learn more about CSA 2010 at http://csa2010.fmcsa.dot.gov/.
    Well hopefully folks will take this as constructive advice and move forward in developing scheduled maintenance plans to avoid the violations during roadside inspections. Those with the I’ll fix it when it breaks mentality are doomed for problems when CSA 2010 takes affect as every ding on a roadside inspection will be harmful to their ability to continue to operate. I noticed several vehicle where there was two tires on different axles with less than 2/32” and on some occasions less than 1/32” of tread on an axle other than a steer axle. The explanation was always the same; “I’m changing that this weekend.” Again the violations are going to have a severe impact on the carrier’s ability to continue to operate once CSA 2010 takes full affect.
    As always, be safe.
  3. eckz
    eckz <strong>"Radio Rambo"</strong>
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    Remind me again, why don't personal vehicles need to go through these procedures?
    Does the federal government really look at statistics, even now, and believe that big trucks are more dangerous than cars are?
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    we can put a robotic truck on Mars, and drive it around by remote control for a couple of years, but no one can develop automatic brake adjusters for trucks that work consistently. Year after year the percentage numbers for trucks with brakes out of adjustment remain unchanged. I don't think it should take rocket science, but it apppears to be more difficult!
  5. Mike_MD
    352
    240
    Feb 4, 2009
    O-Zone
    Are you suggesting that trucks do not present a significant safety risk? When was the last time you heard of an automobile rear ending a bus and killing 7 people? When was the last time you heard of an automobile driver falling asleep at the wheel and rearending stopped cars on the interstate and killing a family of five?
    http://www.ntsb.gov/publictn/2006/HAR0603.htm
    http://www.truckingaccidentattorneyblog.com/2008/06/trucker_sentenced_to_prison_fo.html
    http://www.etrucker.com/apps/news/article.asp?id=51416
    I drive about 25,000 miles a year in the greater Chicago Metro Area. The driving habits I observe on a daily basis indicate defensive driving is practially non-exsistent. Any reports that four wheelers are the cause of the accident are tainted as defensive driving was not used in the determining factor. Drivers with CDLs are supposedly "Professional" drivers and as such should be held to a higher standard.
    The problem is some CMV drivers are in such a hurry they speed, tailgate, and operate the big rigs like a standard family sedan neglecting to watch out for the other driver.
    As a transportation professional that possess a CDL, drove for four years, reviews motor carrier records, and perfoms roadisde inspections I am comfortable in my assessment as stated.
    Denial the situation exist is counter productive. Behavior modification to operate your vehicle safely is paramount to your continued success in the transportation industry. The Drivers Information Resource (DIR) is currently a tool available to only FMCSA personnel; however, Phase II involves making the data available to motor carriers to assess a driver's eligibility to be hired.
    http://www.fmcsa.dot.gov/facts-research/art-analysis-Driver-PhaseII.htm
    Drivers that demonstrate a pattern of violations may eventually be disqualified from operating CMVs.
    IMHO the failure rate is associated with improper installation and maintenance; however, I've been wrong before. :biggrin_2551:
    Be safe.
    drivinhome Thanks this.
  6. eckz
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    The answer to my question, sir, is that it's against the constitution. There is no "CMV" clause in our constitution.
    That's why personal vehicles don't have inspection stops. It was sarcasm, but not necessarily pointed at you. I understand that you are merely a man, with a job to do, and it seems like you take pride in it, it's not your fault that rule makers in this country don't live in the real world.
    To elaborate a little more; There are a lot more rear-end accidents by small vehicles than there are by big-trucks, last i checked, just because they are less reported on the news doesn't make them any less dangerous.
    I've known dentists, and doctors, quite a few of them actually, who have fallen asleep at the wheel and killed people, including themselves. Heck, a few years ago my dad was traveling on an interstate somewhere in his big-truck when a guy in a white jeep cherokee came across the median and hit him head on, the reason? Driver fell asleep at the wheel. It does happen, it's just not "news" to the extent that the media thinks should be covered like a big-truck accident would be.
    Four wheelers are, by nature, generally more inattentive than CDL holders are, our jobs are our livelihood and we are much less likely to ruin that by driving like an idiot, although there are always exceptions.
    Cars are just as dangerous as big-trucks are, and the drivers of said cars are worse, i've had guns pulled on me because drivers diddn't know how to merge and expected me to run over the 3 cars on the opposite side of me so i could get out of their way, because they are more important. I've had cars deliberately cut me off, and slam on the brakes waving their middle finger out the window.. And why? Not because I was doing anything wrong, but because Four wheelers are generally uneducated about what the laws really are for operating a vehicle, and what it takes to operate one of this size.
    I will also remind you that, statistics wise, one should consider the source. What methods do they use to inquire when a CDL holder is at fault, as to what caused the accident? If a big-truck driver was at fault, doing something he knew he shouldn't have been doing (I'd go so far as to say doing something stupid) then wouldn't you think that driver is more apt to agree to questions like "Were you tired when this happened?". It's called an excuse, I don't believe any of the statistics put out by the FMCSA because other than questioning someone there is no 100% fail proof way to prove exactly what was going on inside the cab of that truck. When was the last time you interviewed someone in an at-fault accident and they said "It was my fault, I'm so stupid and i shouldn't have done that."? I'm willing to bet not very often.
    Of course you don't hear about the four wheeler accidents on the news, or on the internet; diddn't you know, only big-trucks accidents are "news", just because you don't hear about them doesn't mean that they don't exist.
    We are slowly giving away our freedoms, little by little behind the guise of "safety". DUI checkpoints are illegal as well, last i checked, but they still get away with it because people let them. Don't even get me started on the state that you operate in, they consider us to be rolling ATM's as far as I'm concerned.
    Let me ask, when was the last time you pulled over a 4 wheeler for impeding traffic in the left 2/3 lanes when they are supposed to keep right except to pass, as the interstate was intended for? Any idea how much congestion this would free up? Chicago has been "Widening" roads for as long as i can remember, but until "keep right pass left" is being followed it isn't going to help, as long as you have a slow mover camping in every lane traffic will continue to be an issue.. The more traffic there is, the more risk you take of having an accident, and it's the same when people are clustered together.
    When was the last time you ticketed someone for not using their turn signal when making a lane change?
    Defensive driving only works when people are predictable, and a lot of them aren't anymore. They are on the phone, playing with computers, reading books even, making wild, jerky erratic movements, they will get on the interstate and go directly to the far left lane for a half a mile and then realize they are about to miss their exit, they will jerk the wheel across 4 lanes of traffic without using a blinker or ever checking their mirror, it's easier said than done to avoid every idiot on the road today, i don't recall ever seeing a big-truck drive like that.
    You say we should be held to a higher standard? Do you realize that a lot of the real professionals have been long gone from this industry, for reasons exactly as I'm outlining here? Companies are forced to hire young, inexperienced drivers who "Have it all figured out" because the veterans who took pride in their work, and remember what the industry used to be like are tired of the politics surrounding it all, it's a two way street. Do you also realize that what you are basically saying is that anybody driving around us (the motoring public) can do whatever they feel like, with minimal to no impact in their driving lives, because we're professionals and should not only be responsible for ourselves and our vehicle/freight but also for them too? This logic is the cause of many lawsuit chasers. It's happening every day, I've seen countless 4 wheelers without functioning tail/brake lights, pulling trailers in the center lane with no blinkers, brakes, or tail-lights, cars without mirrors on either side, but these aren't policed, why? Things go wrong, regardless of how "professional" you are, I see police officers driving like maniacs a lot of the time, should we start forcing them to undergo similar laws? Just because we don't "hear" about a police officer crashing and killing a family of five, on his way to shift change doesn't mean that it won't happen eventually, right? This seems to be the logic now, so let's use it all the way across the board, not just on drivers that are trying to earn an honest living and support their families.
    Also remember that being professional means picking your battles wisely, some accidents you don't want to avoid, it could make matters worse in a heart-beat. Sometimes it's best to just bite the bullet to avoid endangering yourself, or other motorists. There is no point in jerking the wheel, or slamming on the brakes and making a dangerous situation even worse.
    As far as being in a rush, we are given a limited amount of time to drive per day, because even though we are "professionals" that (you say) are held to a higher standard than the rest of the motoring public, we can't be trusted to stop and take a nap when we're tired on our own, the "law" has to tell us when we're sleepy, we have to be micro-managed by the government every step of the way, but we're professionals, right? When do we start being treated like it? I can't remember the last time i pulled into a scale and was actually treated like i was older than 2. We spend countless hours (unpaid) waiting to be loaded or unloaded at shippers and receivers, freight rates are dropping, traffic congestion is the highest that it's been in years, yes, some of us are in a hurry, and yes maybe those that are in a hurry should re-think why, and slow down a bit. Do you want to know how that can be solved? It's not by continually TAKING from the driver, it's by giving something back and this goes back to federal lawmakers who are constantly making it harder on drivers to make a decent wage out there, if we were actually paid for everything that we did instead of 'donating' free time, I'll bet a lot less drivers would be in a rush, and I'll bet a lot less drivers would run illegally.. But when you are forced with a choice of making money to support your family or sitting around for 10 hours when you aren't even tired because the "law" says you have to, what are you going to do? If HOS regulations were in fact set in place to stop companies from being greedy and forcing drivers to run beyond their means then why is the driver ticketed and fined and the company gets away with setting outrageous schedules for it's driver?
    I'll bet there are more 4 wheelers that display this behavior than there are CDL holders, but it's OK for them to do it, right?
    The fact is, you will never avoid every accident that will ever happen. That's why they are called "accidents", it does not matter what you do, period. It will never happen, the FMCSA reports that the trucking industry in general is the safest now that it's been in years, and yet lawmakers are still finding solutions for problems that barely even exist, they are skating around "real" problems and tackling the "easy" ones to justify their existence, at least this is how i see it.
    I don't even want to get into this "system" that you are referring to. Seems to me like there already is one, it's been around for years, it's called the DAC and it's broken. I hope this system you are referring to doesn't have the same flaws, or we're all in a world of hurt.
    Again, i have respect for you. You are a man with a job to do, and this is merely my opinion of a system that i think is both unfair and broken. This is not a personal attack against you, and I'd never take my aggravation for the system out on an officer who's responsibility it is to enforce such regulation, but that doesn't make it any less wrong. In conclusion, no, i am not saying that semi trucks do not pose a significant safety hazard if not properly operated. What i AM saying is that 4 wheelers pose just as great of a hazard, and are left to their own devices despite what statistics say.
    When do we start violating their rights?
  7. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,290
    Dec 15, 2008
    Rochester, NY
    to eckz:
    Bravo! well-said! I couldnt have said better myself! If driving is a privilege and not a right, like lawmakers want us truckdrivers to believe, then why does it matter what type of vehicle I drive?
    Does a dead person asks was that a Kenworth or a Kia, International or Isuzu, Peterbilt or Pontiac,Volvo or Volkswagon, Freightliner or Ford that killed me? (sorry got carried away with the names.)
    My point is no matter what we drive, we have the same potential for death or destruction, CDL OR NOT! The standards should apply equaly for all driver and all vehicles.
    Gearjammin' Penguin Thanks this.
  8. eckz
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    For the record, though, I think Mike is a well intended man, and i want to stress again that this wasn't an attack against him. His posts are well thought out and are from his end of the spectrum.
    Unlike most DOT officers i have to applaud him for actually having his CDL, and for actually doing the job for 4 years, at least he has a clue unlike most.. But this begs the question: Why did you quit?
    Surely he understands some of what we have to deal with?
  9. Mike_MD
    352
    240
    Feb 4, 2009
    O-Zone
    If any of the actions against a CMV driver violated the constitution I can guarantee you a transportation attorney would have picked up on it and made a motion for the practice to stop. I can recall some issue with I believe Arkansas collecting fines on the spot without the opportunity for the driver to appear in court. The problem was fixed by a court order.
    Four wheelers have to contend with DUI sobriety checks and traffic stops the same as truck drivers. What four wheelers do not have to contend with are inspections for safety performed on vehicles in commerce. Commerce is the driving factor for the stops, for the companys to operate in commerce their vehicles must meet the standards set by safety regulations.
    Perhaps, but the end result is much different. The car will not push five vehicles in front of it 100 feet and cause the same damage as a 38,000 - 80,000 pound truck.
    We're all entitled to our opinions; however, as I mentioned before I do a significant amount of time in and around Chicago. I am regularly tailgated by truck drivers to the point all I can see is a grill and set of headlights. You see, I don't drive a patrol car and have no traffic stop jurisdiction; I'm just another driver on the highways with some place to go. I've seriously considered a dash camera front and rear to record the traffic to post for all to see. It amazes me to see two trucks 15' apart traveling at 60 plus mph. The second driver is blind and cannot see anything except the rear trailer doors. Oh well...
    Hopefully you called 911 with a license plate number and discription of the car and driver. Failing to do so is a dis-service to the general public.
    Several states have developed TACT )Ticketing Agressive Cars and Trucks) to address the problem.
    http://www.al.com/news/birminghamnews/index.ssf?/base/news/121507298457140.xml&coll=2
    http://www.nhtsa.dot.gov/people/injury/Aggressive/TACT/pages/TRD.htm
    Doesn't matter what the driver states, preventibility is determined based on the police report of the facts indicated. IMHO many accidents could be avoided by allowing more following distance and slower speeds.
    I was offered some advice by a very wise gentleman many years ago....
    "An excuse only matters to the person offering it."
    Most people really don't care to hear the excuse as it is based on personal beliefs not facts.
    http://www.ksl.com/?nid=148&sid=2062306
    Accidents are in the news all of the time. The fact is accidents involving trucks are much more horrific.
    Truck inspections have been part of the trucking industry for almost as long as its been around. There have always been scales, ag inspection stations, and portable scales. As far as Illinois goes, it cannot be all bad, I see too many trucks rolling along at 65 mph plus to believe there is a fear of being stopped for speeding. If there are other concerns, I am unaware of them as I don't have traffic stop jurisdiction. I perform my inspections at the scales where the trucks are stopped for me.
    Never, I don't carry a side arm and have no traffic stop jurisdiction.
    Do you know the speed limit in Cook, DuPage, and much of Will County is 55 mph for every one? People have a right to follow the law. If you desire to speed then you have to wait until the person moves over.
    I disagree, defensive driving is allowing space for the other dolt to make mistakes because they are un-predictable. I spent 10 years active duty and receive DDC every time I had a permanent change of station. I have attended DDC several time since I left the military for various reasons. Defensive driving allows you to look ahead and plan for unexpected emergencies.
    :biggrin_25523::biggrin_25523:
    Perhaps it's because you're in a truck as well. I witness truckers doing the events you discribe on a daily basis. All I can do is shake my head in disbelief. I see truck drivers with phones to their ears taking notes while driving. I see big trucks take a lane when they cannot get their way. Like I said, I've considered a dash cam to record the events I see on a daily basis. It's scary..... Whooooooo :biggrin_25520:
    Not the pay and benefits huh? Seems to me the cut throat practice of offering to haul freight for less and keeping driver pay scales below an acceptible pay scale is the problem. Combined with drivers that want to hold a steering wheel and stop at every truck stop to watch TV or play video games then complain because they cannot delvier on-time.
    How often have you heard drivers squeal like a stuck pig because the Dept of Labor classified trucking as semi-skilled labor?
    Regardless of what others think truck drivers are "PAID" to drive; therefore, they are professional drivers. They have to understand map reading, geometry, physics, time management, and customer service to name a few. If the driver lacks those skills they are not long for the transportation industry or doomed to work for peanuts because the reputible carriers will not touch them.
    Bull hockey, carriers that pay a decent wage have drivers waiting to be hired. Carriers that pay slave wages cannot fill the seats fast enough and have a 200% plus turn over rate. No one's holding a gun to the carrier's head saying; "Hire the driver or else." It's a poor choice, nothing else.
    No, what I'm saying is truck drivers need to be more cautious to avoid accidents. Use the SMITH System when ever possible. Be one of the drivers with the 1,000,000 miles without an accident, not the yahoo that has an accident every six months. There must be a reason for there to be drivers with 1,000,000 miles without an accident, follow their lead and you'll be rewarded.
    The facts support that when car drivers act irresponsibly they pay for the damages. However, if the truck driver was out-of-hours and should not have been in that spot at that time then the truck driver may be penalized and forced to pay retrubution for damages. The fact is if the truck driver had stopped when they were out of hours they would not have been in the accident.
    IMHO some drivers take jobs without researching the company and end up working harder to make the money the carrier promised. Add the fact there are some drivers that have no business driving with carriers that hire any warm body and you have a recipe for disaster. There are too many drivers in dire straits because they refuse to move to another job. What difference does it make whether you work two full time jobs and are home every day or gone for a week at a time?
    When I drive from 1992 - 1996 the going wage west of the Mississippi was .18 cents a mile while east of the Mississippi it was .24 cents a mile. I thanked my lucky stars when I was hired by WeatherShield Transportation for .32 cents a mile and $10 a stop. I hear some drivers are still driving for .24 cents a mile....... :biggrin_25523: What's with that? Thirteen years and no progress?
    If the driver had used the SMITH System, perhaps there would be no battle. If you're not aware of the SMITH System scroll to the bottom the the first page on the link provided.
    http://www.smith-system.com/custom.shtml
    When the logs are no longer falsified and drivers quit referring to the log book as the comic book then drivers will be trusted. Trust is earned not given. Drivers and carriers have lost the publics trust throught the many occassions where drivers falsified their logs to work more hours. The 1% of drivers that cannot stop and rest when needed and have killed people in the process is what drives the HOS. You don't like the current rules.... Look to your fellow billy big rig truck drivers that keep three sets of logs or no logs at all. Keep in mind the government is reactive not proactive.
    You can stop and take a nap, you just cannot drive after the 14th consecutive hour of coming on-duty. You're allowed 11 hours of driving time and 14 hours on-duty while driving with each 10 hour reset.
    While waiting to select trucks for inspections I assisted the scale operator in getting drivers' attention. Too many drivers approach the scale with their windows rolled up and stereo blasting ill prepared for the instructions available via public address systems. On one occassion I stood next to the sign that rad; "Split Drive Axles Here" and pointed and tapped on it several times. The driver finally rollwed down his window and got a clue to pull up and wait to be weighed.
    You have to understand you are dealing with other people just as frustrated as you are. There is always a new day of un-informed drivers that have their head up their butt that neglect to watch the truck in front of them, roll down their window, and look around for a clue of what to do. Don't judge a person until you've walked a mile in their shoes. I conduct myself professionally and address the driver by sir or madam; therefore, I cannot relate to your question regarding being treated like a two year old.
    Welcome to Life 101. I believe the majority of the American public work extra hours without pay. I know I do and always have, you have a choice, either deal with it or move on. Free will.....
    The Constitution offers every one the "Pursuit of happiness". If you never find it that's your problem, I am under no obligation to cut you a break so you may kill someone later.
    The federal minimum wage is about $7.35 an hour for every American. Are you indicating you make less than $7.35 an hour for all hours worked? If so drop your elected representative a line and let them know how many hours you work and what you are being paid. You should receive a check for the difference. :biggrin_2556:
    Eckz what you earn is based on your abilities and efforts. The government will never guarantee you a wage you feel you deserve.
    Says you:
    I'm sure the carriers above would disagree they are not heald accountable. My job ensures the carriers, not the driver complies.
    I doubt it, there are laws for all stages of life. If you choose to ignor the laws you'll be punished.
    As mentioned CSA 2010 will adress the carrier's and driver's behavior problems. Carreirs that have a pattern of roadside inspection violations that demonstrate a pattern of non-compliance will face notices of violations and penalties and ultimately possibly be shut down. Drivers with a pattern of roadside violations will have their data published on DIR and reputible carriers will not hire them or ultimately be banned from driving CMVs.
    The current death rate for fatalities associated with CMVs is unacceptible and Congress wants the issue resolved. Safer companies and drivers are necessary to accomplish the goal.
    The difference is DIR is based on a drivers roadside inspections, not an office worker that has an axe to grind. DIR is factual, DAC is human emotions.
    Debate is always appreciated. It offers a chance to offer both sides of the subkect for interested parties to make a determination of how people choose to proceed.
    I am a firm believer in defenive driving and I believe every driver should be required to have the course at least every five years to help improve our highway safety... However, I doubt that will ever happen.
    It's every American's civil obligation to stand up for their rights. If you perceive that your rights have been violated then you need to act to correct the situation. Join a group, write a letter do what ever you have to to protect your rights. Waiting for someone else to fix the problem isn't going to work.
    It doesn't, if you accumulate too many points then your license is suspended. If you refuse a sobriety test your license is suspended.
    Driving is a priviledge not a right. That's the facts Jack (or in this case Dave.) :biggrin_2559:
    I don't know if I agree with that or not. I would much rather be reareded by a Geo or Kia Sportage than a Peterbuilt. The law of physics indicate my chances of survival are much greater when hit by the smaller car. :biggrin_2551:
    Recognition that trucking wasn't for me. The days away from home on a regular basis. Treatment by shippers and dispatchers; sleeping in a truck, having to deal with chains in the winter, etc., etc. We all have choices, I went back to school days with a full time job at Sams in the evening. It was tough but we made it.
    In my four years of driving I knew when I did wrong and accepted the OOS for HOS and speeding tickets when issued. I can remeember a dispatcher telling me they would handle any violations when I was asked to deliver a load from Denton, TX - Denver, CO. I told the dispatcher up front two problems, a.) More than 10 hours from Denton, TX to Denver, CO, b.) I didn't have the hours to make Denver, CO on my 70 hour clock. No problem, we'll take care of you. Limon, CO placed OOS for 10.25 hours for the day and 72 hours for the week. Luckily a team driver delivered the load from Limon to Denver. Monday morning took the $39 ticket to dispatch, "We can't pay that." Well that was my last hot load.....
    Tuccumcarri, NM 60 in a 55 mph zone, didn't even wait for the trooper to flip a uie to catch up. Pulled over in the first safe place off the road until the trooper showed up three minutes later.
    I was over 600 pounds on my trailer, dispatch said run with it. Sure, fax a letter instructing me of that and I'll be on my way.... We can't do that... Well then I guess you better have the trailer reloaded, as I'm not leaving with the trailer over weight.
    It's all about choices and how you deal with your own crisis, you have to weigh the consequences of each choice and make a determination whether you're willing to accept the negative with the positive...
    I do but I cannot turn a blind eye when the violation is discovered.
    Be safe.
  10. eckz
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    I'll post a longer response later tonight, but for starters let me just say that I wasn't defending stupid driving, especially not in a big truck, I have never tailgated like you describe, and i do agree with that portion.
    I was making generalized statements from 'the other side' of the fence, statements that you might hear from other drivers on here, I wasn't necessarily speaking for only myself.
    Before this debate goes any farther I don't want you thinking that I'm an unsafe driver, or that I'm excusing it.
    And yes, there are some cases where a driver would earn less than minimum wage if you counted all the time away from home to be work.
    The problem here is that they DON'T move over. You seem to have the same mentality, the signs say "keep right, except to pass" there are NO STIPULATIONS on speed, if you aren't passing you are supposed to be in the far right lane, period. Otherwise they are impeding, especially on a big-truck, who isn't allowed in the left hand lane. I wonder if you are one of the center lane campers i describe, and perhaps that's why you are being tailgated? I can't say, as i don't know you, but if you are then that is probably why. Back soon, cooking dinner.. mm pizza! =D
  11. Mike_MD
    352
    240
    Feb 4, 2009
    O-Zone
    Have you ever seen the traffic in Chicago when you aren't passing some one or about to pass some one? If I'm doing the speed limit, I'm not impeading traffic. Have to get working on that dash cam for the back window to record license plates, etc. and start e-mailing to to safety directors. :biggrin_25518:
    Be safe.
