Odd brake problem.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Diesel Dan 92, Mar 17, 2022.
  1. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    Set of Timpte hopper trains, new in 2017, not a ton of miles on them, yes always greased.
    I have some brakes starting to want to drag, like the chamber isn’t pulling back all the way, tap the slack with a hammer and it retracts like it should.
    The odd thing is, it’s happing on a bunch of wheels all the sudden?
    Everything is normal on the tractor side.
  3. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    ICE in Air Lines??
    Rideandrepair Thanks this.
  4. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    You’ve got a possible trailer brake valve issue or if it’s frozen due to cold temps.
    Or an airline that’s kinked or collapsed internally not allowing the pressure to release so the valve can release the brakes.
    Rideandrepair and BoxCarKidd Thank this.
  5. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    S-cams binding from bad bushings ?
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Wasnt there an air can recall on a ton of chambers a few years ago?
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Sounds like a reoccurring problem so maybe not ice? When they are dragging set the tractor park valve and leave the trailer released. Remove a service side air line from a brake chamber, that is the one closest to the slack adjuster. Was there air on it? Did the brakes relax? If so it is a valve, restriction or ice problem as mentioned.
    It that was not it remove clevis pins from a slack adjuster that has pressure on it. That is easier said than done. Clevis pins could be the problem themselves.
    With vise grips on the s cam can it turned back and forth?
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Yes there is a return spring in the chambers. If that other stuff is good they may be week.
  9. Diesel Dan 92
    137
    50
    Nov 27, 2015
    it is above freezing now and these trailers are a loooooong way from needing bushings…. This sounds very plausible.
  10. cke
    cke Road Train Member
    6,148
    75,675
    Aug 4, 2013
    Colfax Wi
    Brake pedal sticking down ??
    BoxCarKidd and Rideandrepair Thank this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    How much grease do you put in the s-cam tubes?
    Years ago I was first told, only a couple of pumps, you don’t want excess grease getting into the drums.
    Wrong. You pump in the grease until it comes out the slack end of the tube. The seal on the other end keeps the grease from getting into the drum.
    Not enough grease can cause two issues: worn s-cam bushings that then let excess grease bypass the seal so the grease gets into the drums; and stiff, sticking s-cams that operate as you described.
    Just a possibility, could be an air valve problem too.
