Odd brake problem.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Diesel Dan 92, Mar 17, 2022.
  1. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,476
    Mar 18, 2021
    St Malo mb
    Some trailers around that time had abs issues that caused slow release of brakes and hopping when empty on wet or snowy surfaces.
    BoxCarKidd and Rideandrepair Thank this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Hand valve fully returned?
    cke Thanks this.
  4. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    How did you normally repair those?
  5. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    0 psi on control side
    BoxCarKidd Thanks this.
  6. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Foot, hand and possibly tractor protection valve problem would be bleeding air out of tractor service glad hand when disconnected. That is with parking brakes released while the problem is occurring.
    Rideandrepair and Diesel Dan 92 Thank this.
  7. Star Rider
    Star Rider Road Train Member
    1,787
    18,511
    Sep 23, 2019
    Pull the supply line off the valve and check that air is flowing freely , then pull the fitting off the valve and check for debris. If it is doing it on both trailers it will be the lead trailer valve. I have seen that happen on gravel trains here in Michigan.
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Good point. Low supply pressure, flow, can get the spring brakes starting to set.
    Rideandrepair Thanks this.
  9. Star Rider
    1,787
    18,511
    Sep 23, 2019
    Some of the old valves actually had a screen behind the supply fitting that would catch debris, pull the fitting clean out the dirt and good to go again
  10. Diesel Dan 92
    137
    50
    Nov 27, 2015
    I took note of an offending brake yesterday, this morning we took the "parking brake" line off the camber and pushed in the red supply button, seems to be getting plenty of air at the chamber.
    I had an assistant run the foot valve and set and release the parking brake, everything is moving, just seemingly the pushrods aren't retracting quite far enough. A light tap on the yoke with a hammer and they will slide in futher :confused:
  11. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    A brake that offends you one day way not the next. It needs to be checked when the problem is occurring.
    Seems to be and a tee with a gauge are two different things.
