Odd electrical problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Showhauler03, Dec 9, 2021.
  1. Showhauler03
    Showhauler03 Bobtail Member
    22
    7
    Dec 9, 2021
    I have a 98 century with an N14. There is a faint hum or buzz under the driver side Dash with the Ignition off and the tachometer will occasionally twitch. It’s like an ignition solenoid is Not killing the power when the key is off. I also have a crank but no start situation. Any ideas? Thanks for your help!
  3. Showhauler03
    22
    7
    Dec 9, 2021
    Also there are 9.9 V at the fuel shut off solenoid with the ignition key off. Brand new batteries. The noise behind the dash is more like static but it’s not an air leak there is no air pressure.
  4. Showhauler03
    22
    7
    Dec 9, 2021
    I think I figured it out. There’s a starter solenoid on the firewall. It had continuity between the big posts with the batteries disconnected. I think it was the original from 1998 because the posts broke off when I went to remove the nuts.
  5. Rideandrepair
    17,478
    56,691
    Aug 8, 2015
    Good to know. I’ve had a couple go bad, key wouldn’t work, had to jump it at the solenoid. Never had that happen though.
  6. Showhauler03
    22
    7
    Dec 9, 2021
    Well I replaced the ignition solenoid and that didn’t fix it. I still have 9 1/2 V at the fuel shut off solenoid with the key off. The gauges still twitch and the static sound is still present behind the dash. Does anyone have any ideas?
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Hook a jumper cable between a negative battery post and the engine block. Does the 9.5 volts disappear?
    Then try negative post to the cab.
    Oxbow Thanks this.
  8. Showhauler03
    22
    7
    Dec 9, 2021
    Thank you so much for your help! I tried both and nothing changed.I’m not sure if it’s related to the new batteries I just swapped in but the dash says no data link activity.
  9. lilillill
    5,642
    13,472
    Nov 7, 2007
    Did this just start after replacing your batteries? Like immediately after?
    If so, it sounds like you're missing a ground cable somewhere. Double check all the battery connections and make sure you don't have a blown fuse in the ECM connectors in the battery box.
    Oxbow Thanks this.
