Oh Snap!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ristow, Feb 14, 2016.
  1. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    my fan belts were awfully loose. loosened the 4 mounts,and literally touched the adjuster bolt head with the ratchet and it snapped off......
    sooo...my fan belts are still awfully loose.
    good thing its cold out.
    :mad:
    truckon and Pool6710 Thank this.
  3. Chinatown
    Chinatown Road Train Member
    77,521
    182,791
    Aug 28, 2011
    Henderson, NV & Orient
    We used to put tar on the belts so they could gain traction.
  4. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Grab a can of belt dressing.
    Also an easy out set if you don't have one.
  5. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    the fan won't be turning on in this weather. i'll just need to get a new tensioner bolt and put it in. shouldn't be to tough to do.
    i was in there tightening the alternator belt. saw the fan belts were loose too and thought i'd give them a quick fix too....
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Maybe use a pry bar to tension belts for now.
  7. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    can't really get in there with anything,i was thinking the same thing. it'll be alright for now. i just chuckled at how that bolt head pretty much fell off.
  8. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    20.00 bolt and the belts are tight. old bolt came out ok. just took a awhile. i coulda welded a nut on the end and reused it...
