Oil change
Discussion in 'Canadian Truckers Forum' started by Kiddo6, Mar 23, 2020.
Would you use this service?
  1. yes
    4 vote(s)
    30.8%
  2. No
    9 vote(s)
    69.2%
  1. Kiddo6
    Kiddo6 Bobtail Member
    6
    Mar 23, 2020
    Would you get ur personal semi’s oil change done by a company with a van that is equipped with a vac system to suck/clean out all of ur oil plus change any filters and fluid top ups. Done right in a parking lot with ur trailer still hooked up? One hours tops! Average oil change 495$ Looking to invest in such a mobile oil company, looking for advice to see if it would be worth it. Can book online or by phone and make the appointment anywhere in Canada soon to be in the states.
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Yesterday’s responses were pretty obvious .. I suspect today’s will be too
  4. liner
    liner Medium Load Member
    477
    685
    Mar 15, 2008
    ontario
    Not for $495.Thats a crazy price.
    flood and olddog_newtricks Thank this.
  5. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,163
    Jun 3, 2018
    No, that's too expensive. Everyone else is between 300 and 350. You'll never compete with those prices.
  6. oriden953
    oriden953 Light Load Member
    266
    553
    Jul 6, 2012
    winnipeg, MB
    KW winnipeg charges $600 full service... i think id still stick with them over some guy with a van. its about more then just the oil change. will you check my diff level to? grease the truck? check the u joints? do you have the fuel filter with the slightly larger micron that i use for winter?
    even a speedco offers a better deal.
    not sure if the sign is still there but in lloydminster the KW was advertising 199.99 for an oil change for the last few months.. .
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    I don't see the value in 400+ for a big rig oil change. 200 maybe. Undo bolt, drain. Toss filters if any. Spin new one on and refill with fresh oil after bolt back on. Go over truck with grease gun and inspect fluids elsewhere as well as all connections and lines containing same. we don't mind paying a few dollars for time but 400+ is too much.
    We don't believe in the suction stuff either. The oil will come out of there well enough in it's own time.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I do it myself for just over $210.
    Under $300 I'd consider it. for $495 I would expect synthetic oil, which I do for about $375
    baha and Tibs pete Thank this.
  9. magoo68
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Custom truck aka kw Winnipeg is at the bottom of my list for work.. once upon a time they were the top but things really changed..
  10. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
  11. oriden953
    266
    553
    Jul 6, 2012
    winnipeg, MB
    sorry my price was wrong. left KW winnipeg this weekend full service was 523.
