oil consumption
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hardwood trucking, Aug 16, 2010.
  1. hardwood trucking
    hardwood trucking Bobtail Member
    I have a 6NZ 03 model cat that is using 3-4 gallons oil on 10k oil change intervals. NO leaks so does anybody have any ideas on where the oil could be going? Im using Rotella oil with 2 gallons of lucas every time,
  3. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    I don't have a Cat in my fleet. However if there are no leaks anywhere the only thought that comes through my mind is you engine is piston ring wear or possibly blowing by your turbo.
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    or it's blowing out the stack
  5. BIG RIGGER
    BIG RIGGER Road Train Member
    1,071
    414
    Feb 25, 2010
    Fargo,ND.
    Every Cat I ever drove except for a couple needed a gal.of oil after the first 8000 mi.or so on a PM and another gal after 3000mi or so basically every 3 or 4 fuel stops they would need after that first 8000 mi.
  6. old-six-pack
    old-six-pack Heavy Load Member
    757
    82
    Oct 24, 2007
    vernon hill, va
    mine never uses oil,,,,,it's an 03:biggrin_25522:
  7. BIG RIGGER
    1,071
    414
    Feb 25, 2010
    Fargo,ND.
    You should be very thankful.I only drove a couple that were like that but they were built in '05.
  8. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    how many miles and has the eng been overhauled, if so how long ago? if its not leaking, its blowing out the stack or out the blowby tube. might be time for a overhaul.
    rocknroll nik Thanks this.
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Oil use, after the oil is changed, you want to check it every day, write it down, When the oil is changed, you want to take it to a shop and have then put it on there computer at the end of the list of parameters, is the oil pan fill amount. With that you want to have the dip stick checked, You can call Cat and they can give you the amount also. have the serial and arrangement number.
    If the oil level stays good for say 5,000 miles and then starts going down it is rings. If it goes down steadily it could be valve guides or turbo. Cummins makes an oil dye P/N3376891 you add it to the oil it will not hurt anything and the instructions are on the bottle how to test the turbo. If you have oil dye after the turbo you remove it and if there is oil, and dye in the manifold, you have decisions to make.
    If you remove the valve covers and you have carbon around the valves it is guides. You will also have blow by, at high idle and usually use lots of oil if you idle it a lot.
    Just a thought!
    rocknroll nik and DL550CAT Thank this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    ditto rings-valve guides or turbo if its rings a good chance you will have some blowby same for the turbo.
  11. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    2 gallons of Lucas is too much. That is probably what is burning off. That much will make the oil way too thick, and hurt fuel mileage. 1/2 gallon would be more than enough.
