Oil leak
Discussion in 'Freightliner Forum' started by 30 Minutes, Jan 25, 2015.
  1. 30 Minutes
    30 Minutes Bobtail Member
    32
    Feb 17, 2013
    Just had oil pan gasket replaced. Now mechanic noticed a leak behind motor and bell housing. What could be a fix? and the cost? Truck is a 2000 FLD.
  3. 25(2)+2
    18,759
    45,976
    Sep 18, 2006
    the road less travelled
  4. 30 Minutes
    32
    Feb 17, 2013
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    rear seal. if your in need of a clutch soon, then would be the time. no extra labor to do it then.
    30 Minutes Thanks this.
  6. 201
    201 Road Train Member
    12,769
    26,263
    Apr 16, 2014
    high plains colorado
    Roseanne Rosannadanna said it best, "It's always something, if it isn't this, it's that".:biggrin_2559:
    RERM and Cowpie1 Thank this.
  7. 30 Minutes
    32
    Feb 17, 2013
    Had a clutch replaced last 6 months.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Valve cover can leak out of rear an run down back of head then be found running out at bellhouseing, best to ck. the easy things 1st before paying to fix rear seal then finding leak still on ground,clean the eng. with cleaner then watch to see where oil leaks from 1st?
  9. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    How much does it leak? I wouldnt worry if it leaks a little, because its gonna cost you to remove tranny, clutch and flywheel get access to rear seal.
  10. maxfatu
    maxfatu Bobtail Member
    14
    4
    Nov 1, 2013
    everett, wa
    I joust change all the oil gascket and oil seal in a dd15 cost $2000 in Portland or
