Oil question,?
Discussion in 'Ask An Owner Operator' started by feldsforever, Jun 5, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Because I don't own the truck I drive. I don't make any decisions. I wheel into a TA. Request a oil change. As instructed to do so.
    They asked what kind of oil and I just randomly say 5w-30. But please check the previous changes because I don't know honestly.
    So they come around say "we don't have that. But the previous change was 10w-30 delvac."
    Then I started to receive. A explanation on different types of oil. I guess once you put in fully synthetic you can't put in anything eles?
    What is the difference,? I new of regular oil and full synthetic. But what is semi- synthetic?
    And what is cutting together?
    Thanks in advance.
  3. AModelCat
    164,290
    Lmfao typical big chain filter spinner shop.
    I've switched between synthetic and conventional before in several of my own vehicles with no problems. They're just trying to upsell something IMO.
  4. feldsforever
    1,453
    1,440
    Nov 22, 2019
  5. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    Synthetic is like made in a lab so all the molecules are the same size. More expensive up front but longer lasting. Semi synthetic is a mix of synthetic and regular.
    Freightliner recommends an oil change every 10-15k with regular oil, or every 50k with semi synthetic.
    Rideandrepair and feldsforever Thank this.
  6. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    I normally run the delo semi synthetic because that’s what Cummins recommends. If not delo then you can’t go wrong with rotella of course.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Just found out the owner wanted delo. Ill have to remember that in The furture
    The upcharge for I had them put in was 50.00
    Rideandrepair Thanks this.
  8. feldsforever
    1,453
    1,440
    Nov 22, 2019
    What would be a safe point for semi syn. Landstar has him do one every 25k. But asking for my knowledge.
    Thank you
  9. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    Cummins recommends valvoline
    feldsforever and slow.rider Thank this.
  10. mudflap77
    864
    1,314
    Oct 11, 2010
    That not being able to switch myth is well over 30 years old. I didn't think it was still being spread.
    What is more important then if it's synthetic or not is the temperature range the oil grade is recommended for.
    You will hear a lot of people say manufacturer X recommends 10w30 and this is not true. It may come out of the factory with 10w30 but if you read the manual it will tell you to run a oil grade rated for your typical operating ambient temperature range.
    10w30 range. -25c(-13f) to 30c(86f)
    15w40 range. -15c(5f) to 40c(104f)
    0w30 range. -40c(-40f) to 30c(86f)
    5w40 syn. Range. -35c(-31f) to 40c(104f)
    Synthetic oil is more stable at the extreme ends of the range because of this sometimes syn oils are give a slightly bigger range usually around 5c.
  11. slow.rider
    2,005
    4,741
    Apr 4, 2017
    NYC
    Landstar doesn't have him do anything except send in some forms. They have a maintenance schedule form with two options filled in and one blank. For oil change intervals there's options for 10k, 25k, and blank. He can just write 50k in the blank slot and then checkmark that box.
    The manufacturer recommended safe point varies by make and model. The current recommendation for your make and model can likely be found on the manufacturer website.
