When I crank my truck up in the morning, the check engine light comes on saying that engine oil temp is low. This is on a 99 freightliner Century with a Cummins N 14 Red Top. When the truck warms up, the check engine light goes off. Would this be a sign that the sensor is going bad. It also gets a higher temp reading than it usually gets. Not all the time but sometimes. The normal temp reading it has always had is right in the middle. With a heavier load, it is higher which it probably should be a little higher, I am just wondering if this is a sign. I plan on getting an oil sample but just wondering if anyone could shed some insight. Thanks
