Oil usage between oil changes
Discussion in 'Experienced Truckers' Advice' started by Otrliveload, Jul 17, 2019.
  1. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    I think that all truck owners should change their oil whenever they please.
  3. Rideandrepair
    17,541
    56,835
    Aug 8, 2015
    My old rule of thumb, was to change oil when it burned a gallon.12 k on my old Cat, 15 k on Detroit, now I go 20 k on my old 12.7, it’s been leaking/ using 3 gallons. So I’ve been pushing further, with the fresh oil added. After I OH, and fix leaks, I’ll go back to 15 k. Detroit’s original requirement on an old 12.7 old dirty broken down oil burns faster. That tells it all.
    Frontman and bzinger Thank this.
  4. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Not wanting to debate and yes I'm sure I could stretch my drains out more but 17 to 20k drains on my freshly Inframed isx make me sleep better at night .
    This is my last truck until I retire so it gets very babyed.
  5. Opus
    132,052
    Honestly, what @Ridgeline said might be helpful to you. You might be able to stretch out your intervals as well as keeping an eye on your engine.
    Its like your dad swearing by 3000 or 3 months on the oil in his car. That might have made a lot of sense 40 years ago, but today it's just throwing money in a hole and setting it on fire.
    I might start doing the same.
  6. Brandonpdx
    Brandonpdx Road Train Member
    4,705
    4,808
    Dec 27, 2007
    Elkhart, IN
    I would change it at 20k and send a sample in to Blackstone. If they say it's fine I'd go 25k next time.
    MartinFromBC and bzinger Thank this.
  7. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    I only send in the oil every 5th oil change on each truck for testing. But even at 40,000 kms which is around 25,000 miles give or take, it comes back fine, and my trucks do a lot of logging roads, and heavy haul to.
    Hegemeister and bzinger Thank this.
  8. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    I understand what you are saying and thanks ..I'm not changing .
    If this was a truck I was only going to keep 4 or 5 years I'd run 30k drains also .
    But this is my last one and I'll run it till the wheels fall off or I can't pass a physical anymore .
    xsetra and starmac Thank this.
  9. Opus
    132,052
    I'm with you. I'm on my last one as well
    bzinger Thanks this.
  10. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    Oil change intervals. Right up there with who makes the best truck, which brand of beer tastes best. There is no firm answer. Every operation is different. Plan accordingly.
  11. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    How does he not spill oil taking the cap off, and putting the drain plug hose on? Must have a shut off switch the video doesnt show. Also I think I'd use the proper size closed end wrench. Instead of the channel locks he calls pliers. Yo snug up the cap.
    Reason for edit: video removed
