Old cab over options for work
Discussion in 'Ask An Owner Operator' started by Trucker indiana, Sep 8, 2023.
  1. Trucker indiana
    Trucker indiana Light Load Member
    90
    50
    Aug 5, 2019
    I have inherited a 1979 international cab over. I have 3 trucks already on the road, but trying to figure out how to best use this old girl.
    About 750k showing on odom, and was supposedly rebuild about 75k ago.
    It does run really well,
    I do not know for sure the rear ratio think it'd 3.99
    And it has a 400 big cam
    And had a 25 foot flatbed on it right now
    Ok on to my conundrum, I do not see this being a good road truck. the rears are probably bit to low (I do not know but I think I seen a tag that said 3.99 on 24s
    That would but it about 62 mph at 1500 rpm, and 55 mph about 1350 rpm.)
    So how do I work this thing?
    My first thought pull the bed slap a 5th wheel on it and run it as a end dump or grain hauler part of the year.
    Second thought it is double framed (was a hay hauler) so maybe put a dump bed directly on the back, possibly add a tag to get the weight capacity up.
    Any other ideas out there.
    W923 and Concorde Thank this.
  3. roundhouse
    roundhouse Road Train Member
    3,213
    7,329
    Jul 11, 2018
    I think just using it as a flatbed would be the best thing
    Or converting it to a rollback so you could move construction equipment or vehicles locally .
    A 5 th wheel would be useless on something that long .
    I think a 79 would be a small cam in that trans star ,
  4. Star Rider
    Star Rider Road Train Member
    1,786
    18,480
    Sep 23, 2019
    The pic in my profile was a 1977 and had a big cam 1.
    201 Thanks this.
  5. roundhouse
    3,213
    7,329
    Jul 11, 2018
    I stand corrected
    I don’t know exactly when they changed to the BC
    and old transtar with a 25 foot flatbed would be a good farm truck .
    not much good for anything else nowdays
    In the late 80s I had several friends using them for regional work with 48 and 53 foot vans but they were normal wheelbase , and local and regional runs you dont spend all day doing 75 mph
  6. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    Does it have as many winches on the left side as it does the right? If so, that would be a great lumber truck for ltl deliveries. Most of our flatbeds are set up with winch to winch tiedowns and it works great.
    Oxbow and Diesel Dave Thank this.
  7. 201
    201 Road Train Member
    12,763
    26,257
    Apr 16, 2014
    high plains colorado
    Cool, an old "Trashstar", one of my favorite cabovers,,,as if. Equipment trucks like this, generally have low mileage, as driven to a jobsite, pulling something and they sit, I certainly wouldn't use it for any road duty, maybe a spare tractor or VERY local work. I'd remove all the other stuff, maybe put a camper on the back? Dump truck is always a good idea with these old horses, they run circles around newer stuff. Pull a small excavator and small dump is in big demand today. If I was to do anything in trucking again, it would be that, and an old Transtar would be perfect. Great find, they are getting rare.
    Trucker indiana Thanks this.
  8. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Put a pintle hook out back and you can drag a construction style trailer. A few folks run setups like that in my area, behind a flatbed, hauling stones from quarries, hay or PVC pipe loads.
  9. Long FLD
    Long FLD Road Train Member
    12,835
    53,711
    Mar 4, 2015
    Fix it up and take it to shows. If you’re running other trucks then you’d be able to write off the parts and stuff for the rebuild of this one.
    W923 Thanks this.
  10. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Sell it to me. That’s probably the best use of it. I’ll even let you keep the bed.
    W923, Oxbow, cke and 2 others Thank this.
  11. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,568
    Mar 12, 2020
    @Mattflat362 had a similar setup running smaller loads of steel around NE Ohio and seemed to do ok. I used to see him at a Tyson Krupp facility in Cleveland. That might be an option
    W923, Oxbow and Vampire Thank this.
