Older CB radios
Discussion in 'CB Radio Forum' started by Vampire, May 2, 2022.
  1. Vampire
    Vampire Heavy Load Member
    771
    27,453
    May 14, 2011
    Transylvania
    Good evening all,
    Are any of the older radios like the Lafayette brand any good performance wise? Or is it better to just stick with something new?
  3. roundhouse
    roundhouse Road Train Member
    3,213
    7,329
    Jul 11, 2018
    Anything made before all
    The factories moved to China is worth checking out .
    look on the back and see where it was made .
    Japan Philippines Vietnam
    Anything is better than the recent stuff made from chinesium
  4. Vampire
    771
    27,453
    May 14, 2011
    Transylvania
    Thanks for the info. My Grandfather had an old Lafayette. If I bought one, the only question would be who would be best to tune it and not hack it to death?
  5. Ridgeline
    22,717
    123,105
    Lafayette is a good radio if it was made before ‘75.
    I have a few johnson 323a, it is one of the best radios I ever had for receive.
  6. Beachcomber382
    Beachcomber382 Bobtail Member
    4
    Nov 13, 2021
    I collect vintage Lafayette Tube Radios, they are great radios. These days its hard to find someone that works on them, but they are out there. If you're on Facebook, you can contact David Lee, he works on vintage tube radios...Good luck... Dan
  7. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    If a Cobra 29 which costs $100 or less can reach out 30 miles you would be hard pressed to achieve greater results with an antique radio for less money. Chances are pretty good you will spend more and get less performance. Antique radios require maintenance and labor isn't free.
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I had a 23 channel Johnson I bought when I was a kid in the ‘70’s that may have been the best radio I’ve ever owned. Send or receive I never found anything that would touch it out of the box. I had that radio in my trucks until it finally blew up in ‘85 or ‘86. I replaced it with a Cobra 25. Got lucky with that one too. That radio still works, only been opened once I can remember for a repair, and it crushes the new 29’s.
  9. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    They were the best mobile CB radios ever made. I still own a 123A and a 123B. They still work, but the capacitors do need to be replaced.
  10. kemosabi49
    10,976
    47,913
    Jan 13, 2013
    SW Arkansas
    I has a 23 channel Johnson and it was probably the best radio I ever ran. I took it out when I started driving a truck that already had a radio in it. Don't know what ever happened to it.
  11. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Just amazing radios. A decent antenna on them, on the lower channels you’d get almost the same truck to truck range as some of the SSB sets would do in the same area. A lot of guys had them because the VHF sets for industrial roads in a lot of trucks were Johnson radios. Drivers would get a screaming deal on a CB from whoever supplied those. They were pretty common in the bush and up north, but I can’t remember the last time I saw one now.
