Onboard Scales
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hoofbeats, Feb 13, 2010.
  1. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    I'm looking for any input on onboard scales.Anybody use them?Which one is the best?Are they worth it?
  3. passingthru69
    I have a set of wireless on board scales
    I have a hand held unit and can read each axle grouping.
    Was a pain when I first got them to set up the mty. lded. wghts. but I like them very much..
    Just word of warning, if using a wireless tire pressure system they work on the same frequency..
    False readings on both then.
  4. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    i have right weighs on both my trucks and all my trailers. really like them, inexpensive and they work.johnny
  5. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    air gauges work great, and cost less than a couple hundred bucks for an entire set up.
  6. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    my tractor has a PSI guage for the rears, it's a PITA, when it reads 60 I'm at 36,000 on my drives.
  7. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    Those gauges are only accurate when on level ground .
  8. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Level ground with the brakes released on the axel group that you're reading. On mine the tandems are 34,000 even at 60 pounds on the tractor and the trailer, The only variable is the steer axel but if my 5th wheel is in the center of the tandems it's just not possible to overload the steers, They're usually at a max of 11,800 when it's in that position.
  9. Hoofbeats
    1,250
    1,991
    Jan 27, 2010
    Iraq
    I've been looking at these:
    This one seems like it would be more accurate.
    http://www.truckweight.com/EN/documents/2008 - Air Suspension.pdf
    http://www.air-weighscales.com/download/pdf/AW5800_Bro_902-0035-003rev1.pdf
  10. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    I have a set of the air-weigh scales on one of my trailers and my tractor, which
    I like very much. They work really well and we plan on putting them on all
    of our rigs.
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    The air scales are the same, all their doing is converting the same pressure a $10 gauge sees into lbs. You can buy actual load cells for a truck suspension, 5th wheel and front axle but they're very expensive.
    The Air-Weigh instructions tell you to "Weigh on level ground with brakes released and engine running". There's nothing magical about these systems. You still have to calibrate the system with a set of truck scales, exactly like you would with a cheap gauge. The air systems will make your wallet lighter, no calibration needed.:biggrin_25525:
