One axle locking up
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NightLight, Aug 7, 2019.
  1. NightLight
    NightLight Bobtail Member
    27
    4
    Aug 12, 2013
    Indiana
    I recently replaced the brakes and wheel seals on the front drive axle.
    Now that axle will lock up when the brakes are applied, loaded or empty
    Also (maybe unrelated) application pressure gauge has stopped working
    '16 pete 579
    No abs light/code
    Any ideas would be greatly appreciated.
  3. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    check ur slack adjuster or ur s cams, make sure ur brakes were adjusted correctly also after changing brakes and that the brakes were released with at least 100 psi in the tanks when they were adjusted.
  4. NightLight
    27
    4
    Aug 12, 2013
    Indiana
    Slacks are good. So are s cams and bushings
    Adjustment checked 6 times and air at 100 plus.
  5. wtokhi
    251
    115
    Nov 3, 2017
    any service done to the power divider?
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    The rear axle components and adjustments are ok as well? Im guessing that there is something wrong in the distribution of air from the pedal to the axles as the brakes should wear at the same rate one would think.
    NightLight Thanks this.
  7. NightLight
    27
    4
    Aug 12, 2013
    Indiana
    Yes sir, as far as i know.
    The rear axle brakes were replaced shortly before i bought the truck last year. The front axle needed done now.
    They were still legal just, not to my liking.
  8. NightLight
    27
    4
    Aug 12, 2013
    Indiana
    No. Nothing done to power divider
  9. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Brake spring hardware incorrect/missing? Scam bushings wore out?
    spsauerland Thanks this.
  10. NightLight
    27
    4
    Aug 12, 2013
    Indiana
    the s cams looked good and, we used all the new hardware that came with the kit. This is happening on both sides, btw.
    Not sure if i made clear in the op
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Incorrect brake shoes?
    spsauerland, Dino soar and Diesel Dave Thank this.
