Orientation Road Tests ( hitting curb )
Discussion in 'Questions From New Drivers' started by Landser14, Oct 3, 2013.
  1. Landser14
    Landser14 Bobtail Member
    22
    4
    Aug 5, 2013
    So this past Monday, I had an orientation for DM Bowman, after the DOT physical and Drug Screen ( which I though was stupid, they should of done road test first ) I hopped into the cab of a truck for the first time since graduating trucking school back in Mid-June. There at DM Bowman, for the road test, they require you to do a pre-trip, hook to a trailer, do brake test, go on road course, then back into a dock. I did my pre-trip, hooking up to a trailer, and brake test flawlessly.
    I started the road course itself, and about 15 minutes in ( it was about 25 minutes total ) I made a right turn at a 4 way intersection and my trailer tires ran up on the curb a little bit. They weren't like 10 feet up on it. So I drove a little further and we came back to the terminal where the trainer told me to try to back into a dock. It took me 3 tries to get in it, but I wasn't perfectly straight. So he told me that's fine, and to shut off the truck and walk inside with him. Right when we got inside, he told me that since I hit the curb, I automatically failed the road test and thus I was sent home. He said that hitting curbs, even brushing against them, is an auto-fail. I was frustrated, I was being hired as a student driver. Students are bound to make mistakes.
    So my question is, do all companies have that same policy? Where if you hit a curb on your road test, you automatically fail?
    I have another orientation scheduled next week for US Xpress and I wondering if they do the same. Like I said, I haven't driven since mid June, and I thought I did pretty #### good. Sure I grinded some gears, because I wasn't used to the truck and I was giving it too much RPM, but I never missed a gear, never had to come to a complete stop.
    I'm just very frustrated
    DoneYourWay Thanks this.
  3. BrenYoda883
    BrenYoda883 Road Train Member
    1,248
    1,422
    Sep 18, 2013
    Curious.. why didn't you get on with a company right out of school?
    In this industry, and having 0 experience.. 3 months out of school is tough.. it actually takes longer than the littl time we spend in school to actually learn to drive.. so as time passes and you are not in a seat learning things become rusty and think about it.. yes, you only grinded a few gears and hit a curb.. but if that was your truck it would be a bigger deal....
    No body owes you the opportunity to learn to drive..
    What. School did you go through.. will they let you go get in the truck and sharper your skills to be able to pass a raid test..
  4. CaliforniaxCowboy
    CaliforniaxCowboy Light Load Member
    108
    90
    Apr 12, 2013
    The key is to hire on with a starter company directly after finishing school, like literally a week or two after. Waiting months and then jumping in to it puts you at a disadvantage because you don't really get much time to practice in the schools and 90percent of learning to drive a truck is practice.
    You sound like a typical new driver. Grinding gears, hoping up on curbs, taking a minute or three to back in...we've all been there. Plenty of other trucking companies will work with you just as you are. Hell, I've seen some of them take much, much worse...
  5. Landser14
    22
    4
    Aug 5, 2013
    I waited to get hired because at the time I graduated in June, I was only 20 years old. I did not turn 21 until the last week of August. Nobody would hire me while I was under 21 ( even local companies ). Thus is why I'm just now getting started months later.
  6. TripleSix
    133,269
    Instead of looking to avoid companies that have the no curb policy, how about concentrating on fixing what you did wrong?
    Do you know what you did wrong? Yes, I know that you weren't 10 feet up on the sidewalk and caused lots of damage and stuff...but in your setup, before you started your turn, what could you have done differently? See, there are some towns and cities that have signs and light poles right at the corner....EVERY corner. The goal isn't to pass a driving test, the goal is to show them that you can be a good productive driver if they hire you.
    So, bet on USX having the same policy. Bet on all companies having that policy. And when you take their road test, fix your setup before you turn.
  7. Landser14
    22
    4
    Aug 5, 2013
    I know what I did wrong. I entered the turn correctly like I was taught ( it was a seperate right turn lane with a yield sign ). I was taught, that when coming out from the right turn lane, you continue out forward and turn just before you get to the median, and then go back into you're lane. I did not go all the way out to the median before I turned because like I said, not driving for almost 4 months, I'm going to make mistakes, I'm not going to go out and do everything the same way a veteran driver does.
    And no, the school I went to does not give any kind of " refresher courses ", nor does any other place around me.
  8. cowboy_tech
    cowboy_tech Road Train Member
    2,290
    1,093
    Sep 27, 2008
    Avondale, CO
    I thought hitting a curb in a normal cdl test was always an automatic failure. They are just using the same standard that was used when you tested to get your CDL.
  9. rwdfinch50
    rwdfinch50 Medium Load Member
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    That's what I was getting ready to say. It sounds like Bowman is simple erring on the side of what the DOT requires in a driving test.
    I do think since you are a student, they should have given you a break on that, but it's their choice.
    You shouldn't let it bother you too much, just do better with the next road test, and give yourself enough room.
    By the way, if my memory serves me correctly, I never had a road test before the hiring process was complete. In fact, I don't think you can legally get behind the wheel of the truck, even for a road test until you have the drug screening and DOT physical. I may be wrong with this, but I don't think so.
  10. NewbiusErectus
    NewbiusErectus Medium Load Member
    587
    621
    Jun 27, 2012
    Yeah, driving tests and running over curbs usually don't mix well.
    OP, if they're handing you the keys after you pass the test, hitting curbs will probably get you failed. If you're being trained as a new driver (going out with a trainer first) fresh out of CDL school, they'll probably tolerate it a few times.
  11. TripleSix
    133,269
    As long as you know what you did wrong, you should not repeat the mistake, right?
