Outside power outlet use?
Discussion in 'Questions From New Drivers' started by ImpurestCrowd, Mar 1, 2015.
  1. ImpurestCrowd
    ImpurestCrowd Bobtail Member
    23
    Jun 16, 2014
    Zephyrhills,Fl
    OK a newbie question here, the truck I'm riding in now team has an outside power outlet that I have a few ideas what its for but nothing definite and the other codriver doesn't know either and says he has never used it.
    1) engine block heater
    2) to power the truck so you dont have to use the apu or keep it running
  3. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Most likely a block heater. The truck I'm in has 2, one for a block heater and one for shore power. Previous trucks just had one, and it was for a heater.
    tscottme Thanks this.
  4. Cat sdp
    Cat sdp . .
    21,299
    76,152
    Apr 8, 2012
    Orion's Belt
    If it's on the drivers side follow the wiring...
    If it goes strait to the engine top end it's a block heater....
    never seen a shore power set up in person so I can't help......
  5. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Its for your trk on those extremely cold days.kb has them and at the end of the drivers shift they plug the trks in.On weekends the mechanics put the day cabs in the garage.
  6. rzl-dzl
    rzl-dzl Medium Load Member
    477
    175
    Dec 16, 2011
    100 mile house
    or oil pan heater.
  7. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    That's required for the extra amps a vibrating bunk bed draws!
    Seriously, it's almost for sure a block heater but to be safe get a looksie at under the hood wiring.
  8. oriden953
    oriden953 Light Load Member
    266
    553
    Jul 6, 2012
    winnipeg, MB
    does the cap/ cover on it not say what its for?
    and where is it located?
    my volvo has one under the driver door area and the black cover says block heat. theres one more under the bunk area that says shore power.
  9. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    Really? When I had a full head of hair, I used to plug in my hair drier so I would have the "perfect do"~!
    My current job, I plug in my truck each night, to keep the engine warm, so to the o/p, if you have a truck with such a plug, use it all the time you are parked at your terminal, or if you take the truck home, plug it there. If no electrical outlet available to you, oh well. We all cannot have that, so don't worry about it.
  10. ImpurestCrowd
    23
    Jun 16, 2014
    Zephyrhills,Fl
    Yeah I just followed the cables and it looks like it goes to the engine so I'm assuming it is a heater. Thanks for all the replies
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    plugs in the front of the driver door are usually engine heat.
    plugs under the sleeper are usually for shore power.
    that's usually the location for the 2 plugs.
