Overhaul..question
Discussion in 'Ask An Owner Operator' started by Call me hooper, Nov 20, 2019.
  1. Call me hooper
    Call me hooper Bobtail Member
    15
    12
    Oct 21, 2019
    06 century. Detroit serious 60..question is can I use cruise control after overhaul.. I heard you not supposed to do that.. u gotta run at least 5k miles or more
    SimpleTrucker Thanks this.
  3. fordry
    fordry Bobtail Member
    22
    14
    Aug 27, 2019
    Well, I don't know about truck engines specifically but I know it was recommended to my family when we got a new block for our boat to put 20 or more hours on it varying the speed frequently before running it at constant speeds. Wouldn't surprise me if a truck engine overhaul needs something similar.
  4. Brandt
    Brandt Road Train Member
    4,622
    6,354
    Sep 17, 2012
    I was always told to run them hard or normal. You don't want to idle them. You have set the new rings. If the rings don't set good you get blow by. So that why you don't idle a new diesel engine. The S60 would get a lot of blow by when new at idle. So you run it hard or normal, pull some hills keep the engine hot and working to wear in the new piston rings . Make sure you give it 3 minutes minimum to cool down before stopping engine and 3 minutes minimum before working engine hard.. that what I did when I had S60
  5. jamespmack
    216,477
    Dont idle except warm up/shut down.
    Found best results breaking it in on a dyno. Then drive it as normal.
  6. 201
    201 Road Train Member
    12,751
    26,222
    Apr 16, 2014
    high plains colorado
    I wonder who told you that? I don't see how a cruise control( I think the new term is "speed control") is any different than your right foot. I was told to "get 'em hot", no idling.
    Bean Jr. and mhyn Thank this.
  7. Call me hooper
    15
    12
    Oct 21, 2019
    A mechanic told me..if you stay in one speed you'll ruin the engine.. I tried cruise control yesterday few times..but got scared after few minutes and took it off.
    201 Thanks this.
  8. Call me hooper
    15
    12
    Oct 21, 2019
    I get the idle.. but I wanna find out about cruise control..
  9. AModelCat
    164,355
    Just drive it lol. Rings seat in within the first 5-10 minutes.
    Don't idle excessively, make it work. Can't really see how holding a constant RPM is gonna ruin anything lol. Pistons go up and down, crank and cam go round and round.
    npok, Oxbow, Dino soar and 6 others Thank this.
  10. Brandt
    4,622
    6,354
    Sep 17, 2012
    If I remember correctly it takes like 20,000-30,000+ miles to break in a S60 engine. So running the cruise control is not a problem. Don't forget to change the first oil change like 5,000-6,000 miles. You could even change first oil like 3,000 miles maybe do another one at 7,000 miles. That's up to you
  11. 201
    12,751
    26,222
    Apr 16, 2014
    The cruise control does not hold it at one RPM, like a stationary motor. It let's up on the pedal going down, and mashes it going up, just like your foot. Don't be scared, buckaroo.
