Overhauled engine
Discussion in 'Ask An Owner Operator' started by pavrom, May 14, 2019.
  1. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Im about to go pick up my other truck with freshly built c15 single turbo , i have to drive 1500 miles back home . I hear from other people ( mechanic who did the work as well ) that truck has to be put under load right away to have rings properly seated etc . Would like to hear opinions from experienced people ( yes i did my research as well )
    Ps
    My current truck i drove from same mechanic 77k miles again , so far so good ...dont have any issues ... Not sure what my options or issues can happen
    Didn't talk to my dispatch about power only loads from UT
    Carlinho Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    A
    Are you asking if it's ok to drive your truck bobtail 1500 miles to get your trailer.
    I had a fresh overhaul in January. Was told the same thing run it hard. Push it.
    My first load was a power only. 300 bobtail miles to the pickup. 1200 miles with a 15000# trailer. 900 bobtail back home.
    My motor runs just fine. When bobtail the mechanic told me to drop a gear an run with high rpm.
    Since then I have ran a few 45,000+ loads west thru the mountains. The rings have definitely seated properly.
    What I read about the rings seating was keeping the temperature of the motor on the high end of range. Not overheating just high on the normal range.
    Don't idle the truck more than it takes to get operating air pressure in the system.
    Don't run low rpm, or lug the motor.
    Just my experience with one overhaul. Many better mechanics on here than me.
    Good luck.
    Bean Jr., tommymonza and motocross25 Thank this.
  4. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    ...yes i meant bobtail ...i was thinking 1550 rpm and 0 idling for first 10000 miles ( did it with my current engine ) ...not sure why im so concerned ..just wanna prolong the engine life i guess
  5. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    Yes run the motor hard!!! Blow it again so we can charge you another $15,000 to fix it...
    mhyn Thanks this.
  6. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Im trying to prevent this actually ...i doubt i will blow it though at my end
  7. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    If the overhaul was done right, then it should last a long time...
  8. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Would be nice if you can do overhaul on my other c15 for that amount :)
    Joetro and win-some-loose-less Thank this.
  9. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    I would vary the rpm. 1550 for 15 minutes then drop a gear and run it up to 1950/2000 for 15 minutes, then shift and drop the rpms back down. Repeat. Try and hit every range between 1400 and top rpm. The biggest thing is not letting it idle or lug.
    Bean Jr., wore out and tommymonza Thank this.
  10. AModelCat
    164,482
    Load it up. Make it work. No better way to break an engine in than on a dyno.
  11. bigtravelr
    bigtravelr Light Load Member
    104
    128
    Jul 8, 2017
    Take it to a Dyno and they have a run in procedure the they can do on the Dyno. Cost around 300 bucks or so.
    jamespmack Thanks this.
