Oversize or not?
Discussion in 'Flatbed Trucking Forum' started by JPHeavyHaul, Jul 4, 2019.
  1. JPHeavyHaul
    JPHeavyHaul Bobtail Member
    11
    47
    Jul 4, 2019
    I'm hearing conflicting information whether or not I'm oversize. I don't think I'm oversize according to the state websites. So I'm here to try and find a definite answer from someone that has more experience than I do.
    Both states have 75' overall with max. 10' rear overhang.
    I am in Nevada right now Delivering to California.
    Here are my dimensions.
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Nah you good.
    Tandems 6th hole nothing else to worry about
    Lepton1 Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Under Nevada you are not oversize provided you are 75 feet and less than 10' overhang.
    Normally anything beyond decking is oversize. But I am not Nevada. I checked theirs.
    One thought. You did not say how high.
  5. Espressolane
    18,649
    116,825
    Well, let us know how it goes.
    That will help others for the future.
  6. Long FLD
    Long FLD Road Train Member
    12,827
    53,672
    Mar 4, 2015
    Not true in most states out west. Spreading false information doesn’t really help anyone.
  7. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    In Florida yes you are oversized but I have never driven out west so idk
  8. Long FLD
    12,827
    53,672
    Mar 4, 2015
    WA and WY require permits based on what you’re hauling and length of material. Other than that as long as you’re under 10ft off the back and have lights and flags if you’re over 4ft overhang you’re good to go.
    Idaho gets picky about front overhang. You need lights and flags if you’re more than 4ft over the front of your trailer too.
    sawmill, x1Heavy, Oxbow and 1 other person Thank this.
  9. x1Heavy
    34,016
    42,143
    Mar 5, 2016
  10. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    What you speak of is somewhat true for a 48. I'm not sure a 53 gets quite the same standards.
    WY requires permit for anything that exceeds 60 ft. If you're hauling 60 ft rebar but the distance from front to back is an extra inch. Because none of them will be ligned up perfectly in the front or back.
    WY also wants lights on the rear AND the side of rear overhang
    AZ requires permit anything over 6 ft. rear overhang.
    CO allows 10 ft. IIRC, CA was the same.
    IIRC, NM was 8 ft.
    As for the OP.
    AZ measured my truck and 48 @ 65 ft. My next truck was 68 ft. Boss was hoping to avoid as many permits. So the wheelbase was 3 feet longer. To put more overhang on the front. A 53 would have put me at 73 ft. OP must have a long wheelbase truck.
    Boss mostly did Cali. The first truck was manageable. The second truck really sucked and resulted in a couple slashed tires on the trailer.
    LoneCowboy, D.Tibbitt and x1Heavy Thank this.
  11. Long FLD
    12,827
    53,672
    Mar 4, 2015
    WY would measure I-joists too and the 60 footers were generally a few inches over 60. We had to start telling them 61 foot. And then they wanted flags and signs and the whole 9 yards. I started running up out of Logan to Bear Lake and dropping back down to Evanston just so I didn’t have to deal with the Port.
    sawmill, PoleCrusher, Oxbow and 2 others Thank this.
  12. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    That is within my understanding also. More or less. Usually three feet. The lumber trucks here with cut pine hanging 15 feet back their racks get a small flag hung on the end of the log.
    I don't have issues with LongFLD at all. it's a matter of trying to resolve. Ultimately if it was me with that load in Nevada I would be calling the Law at the Permit Board and give them the information. Do I need permit or not and if so how much and what Curfews, routing etc.
    I have extremely little oversize experience. It's enough for me not to deal with hauling houses through a town if I can help not to do that. Be a cat on a hot tin roof unable to get off.
