Oversized/dolly
Discussion in 'Experienced Truckers' Advice' started by millsjl01, Aug 31, 2014.
  1. millsjl01
    millsjl01 Light Load Member
    298
    375
    Jan 24, 2012
    Driver seat/sleeper berth
    I don't know what they are called exactly, but the square piece at the end of an over length truck...usually a windmill blade or beam...who controls it?
    I've heard that on surface roads its someone in the pilot car, but also have heard the truck driver is controlling it. I don't really see how that is even possible...or safe.
    So, anyone got an answer on this?
  3. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    The answer could be both. Depends on trailer. Some have a remote steer control in tractor cab. Some have a remote they can give to the escort and they can control the steer dolly.
    okiedokie and millsjl01 Thank this.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    striker and millsjl01 Thank this.
  5. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    If it's the little "square box" that I think you are talking about, if you look close at that little box you will see someone crunched in there and he/she will be the one that is steering it. Never heard of a remote steer by an escort or being steered by the driver, but really dont know
    millsjl01 Thanks this.
  6. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    The rear dollies that I pulled had a remote control that was given the rear escort. It was probably 4"x6" and it could raise or lower the load, steer left or right, lock or unlock the steering pin, and start and stop the rear engine. Some of the bigger trailers I have seen had a platform for the steerman to stand on when going around corners. The ones with the little cabs under the trailer I have only seen pictures of. We had a Roehl driver who came from their bridge beam division who said their trailers steered by a box that was in the cab of the tractor.
    rockee and millsjl01 Thank this.
  7. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    The only one I’ve heard of that is driven by someone in the dolly itself are used by Boeing when transporting aircraft parts, I guess there might be others but I think most are done by a Pilot car.
  8. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Well in that case would the pilot car driver be required to have a CDL? Sure would not want to be that guy riding in that box under the trailer.
  9. passingthru69
    There has been alot of issues about question.
    Some states were saying yes they had to have CDL others said no.
    Now if you are in the stand up cage and it has a hand valve to control the brakes, yes you do need a CDL.
    Ny. has some weird rules on that as well. Depends on the ld. and the steering system.
    Also, the steer man can not be a pilot car driver escorting the ld. Has to be a driver who can ride with the rear pilot car.
  10. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Its called a Jeep, and both drivers have to have CDL's. I hauled bridge beams in the 90's.
  11. okiedokie
    okiedokie Road Train Member
    13,710
    108,235
    Jun 13, 2011
    PNWET
    I drove a steer car hauling beams and poles a few centuries ago. There are also other steer trailers. Depends on the application and load.
