Overweight on Steers
Discussion in 'Questions From New Drivers' started by ZhenyaP1991, Jul 6, 2016.
  1. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    Been driving current truck for 1 month and some, doing OTR. Scaled couple times at the shipper, never really noticed it. Yersteday, I scaled my load at fj, and came out Steers 13500, Drives 32340, Trailer 33160. Umm what? I thought 12000 was the max and Its a fixed fifth wheel.
  3. AModelCat
    164,637
    Chances are it was set up wrong at the factory or there was some heavy aftermarket options (like an APU) installed near the cab. Only way to fix it is to unbolt and move it back a couple inches.
  4. AModelCat
    164,637
    Also, what is your GVW? Some areas let you run a heavier steer axle/tires so you can gross more.
  5. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    You'll have to move your tandems to get some of the weight off your steers.Move tandems three holes and you'll be fine.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    13.5k is pushing it. I've always been comfortable with anything under 12,800 and never been bothered anywhere with such weight. If you were to ever achieve 34k on your drives, your steer tires are going to be about ready to pop at probably near 14-14.2k
    But I have to tell you, somebody spec'd that truck like that, and with a fixed 5th wheel, and they really screwed up unless you're in some sort of "heavy-haul" spec truck with big tires and HD axle up front.
  7. SHOJim
    SHOJim Road Train Member
    3,399
    17,211
    Apr 19, 2011
    Columbus, Ohio
    Put your steers on a diet. Oh your talking about truck.
    D.Tibbitt and otterinthewater Thank this.
  8. albert l
    albert l Road Train Member
    1,040
    1,505
    Feb 10, 2013
    On the Road
    What did your company say when you asked them why the steers are scaling so heavy ?
  9. ZhenyaP1991
    573
    702
    Nov 6, 2014
    Already delivered that load and its done with, but wouldnt I get pulled in at the scale? Its bothering me, what if scale is wrong? And how I did not noticed it before?
  10. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Moving trailer tandems is not the issue nor is it going to address the issue.
  11. ZhenyaP1991
    573
    702
    Nov 6, 2014
    Lol, don't worry about that. Just got done with reserves.Ask me in couple of years
