overweight permit question
Discussion in 'Oilfield Trucking Forum' started by Malleus2, May 28, 2016.
  1. Malleus2
    Malleus2 Light Load Member
    87
    15
    Mar 29, 2015
    I should know the answer to this but I dont lol anyways here it goes...
    If the tractor I'm in has an Overweight permit would I be able to take a road with a weight limit posted on it?
    Road is posted 60k while the loaded truck is about 90k
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    If the permit routes you on that road I would say you are OK. It would be nice to know if there is a light bridge down that road. Maybe try and contact the local Sheriffs ofc. If you are talking about an annual permit, no I would not go down that road.
    Malleus2 Thanks this.
  4. Malleus2
    87
    15
    Mar 29, 2015
    Well hell.... thanks for the response. now Im just glad I never got pulled over while riding heavy down these roads -.-
  5. xsetra
    xsetra Road Train Member
    5,168
    7,100
    Aug 21, 2011
    No. Your permit does not give you permission to exceed posted weight limit on bridges. You should contact highway department to verify actual bridge capacity.
    It might be an outdated bridge posting.
  6. QualityMike
    QualityMike Light Load Member
    288
    201
    Jun 19, 2011
    North Dakota
    Are you talking about an Extended Weight Permit or a one time Over Weight Permit. If is a one time Over Weight Permit, it should have an exact route for you to take. If it is an Extended Weight Permit, which is an ongoing over weight permit, the state will have a map of the roads that you are allowed on.
  7. RockinChair
    RockinChair Road Train Member
    5,238
    13,554
    Feb 19, 2012
    Lubbock, TX & thereabouts
    In Texas, a Weight Tolerance permit issued by TxDOT is not valid on the interstate (and possibly on non-interstate highways). I think that it will allow you to exceed the posted weight limit on a load-zoned state highway, farm road, or county road, assuming the county you're in is listed on the back of the permit.
    I don't know if the permit will allow you to exceed the posted weight limit on load-zoned bridges. You'd best check with a License & Weight trooper for a definitive answer.
