Overweight
Discussion in 'Experienced Truckers' Advice' started by jjpaez123, Oct 11, 2019.
  1. jjpaez123
    jjpaez123 Bobtail Member
    24
    11
    Dec 26, 2014
    Can someone please help me!
    if a truck is overweight
    Steer Axle 12060 lbs
    drive axle 35000 lbs
    trailer axle 33760 lbs
    Gross weight 80820 lbs
    and the fuel-tank is empty how much weight am I supposed to remove from this load ?
    catdog45 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    200 gallons of fuel. X roughly 7 lbs per gallon. = roughly 1400 lbs.
    1400 + 820 = 2220 lbs.
  4. jjpaez123
    24
    11
    Dec 26, 2014
    so If each pallets weights 950 we will have to remove about 2 pallets ?
  5. Chinatown
    Chinatown Road Train Member
    77,691
    184,144
    Aug 28, 2011
    Henderson, NV & Orient
    I always top off the fuel tanks before picking up a load.
    I'd remove at least 1500 lbs. from the nose and that's leaves 500 lbs. for fuel.
  6. jjpaez123
    24
    11
    Dec 26, 2014
    that's exactly what I told the carrier to have his driver to fuel his tank before picking up he said that was not necessary.
  7. Chinatown
    77,691
    184,144
    Aug 28, 2011
    The dummy should have listened to you.
  8. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Always gotta have at least 1/2- 3/4 fuel
    And you’re 2 pallets over weight
    catdog45 and jjpaez123 Thank this.
  9. tscottme
    tscottme Road Train Member
    At least 820 lbs, which would go along way to reducing your drive and steer axle violations. I'd call it an even 1,000 lbs to be removed and then you are legal but going nowhere due to fuel exhaustion, so the DOT and the Greenie Weenies are both happy.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    the problem is on the front. always set your trailer at the 41'. get loaded and weight. if not correct then take it back
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If it was me, I would move 1000 pounds to the steer and ride watching my fuel, if it is going to be a pain to lose some weight.
