Owner operator parts
Discussion in 'Ask An Owner Operator' started by mtclex, Jul 20, 2025.
  1. mtclex
    mtclex Bobtail Member
    37
    43
    Jul 6, 2022
    Where do you owner operators typically buy your used/new parts from? I’m looking for tie rod for a 2017 Mack pinnacle and only see one for 2k. I’ve found the RH and LH replacements parts and they’re about 500 to 600 a piece. Any help would be much appreciated.
  3. sirjeff
    sirjeff Medium Load Member
    For macks and volvos, definitely Dex Parts. Ive bought a complete engine from them as well as some fuel tanks
    DEX Heavy Duty Parts - DEX
    86scotty and mtclex Thank this.
  4. mtclex
    37
    43
    Jul 6, 2022
    Thanks, driver
  5. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
  6. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    For new suspension parts I'd call Stengle Brothers in PA. For used parts I'd call Holst in Idaho. I would never put a used tie rod on though.
    01HFT Thanks this.
  7. abyliks
    abyliks Road Train Member
    4,110
    9,662
    May 2, 2010
    ludlow MA
    Suspension I go to a local spring/frame shop, I don’t buy used
  8. Ridgeline
    22,720
    123,238
    Even with my discount, they are about $600 each. I have bought Meritor and Mack, they wear the same, and that's alright. Never buy used, safety first.
    The cost is a shock, but it is part of being an O/O.
  9. Tug Toy
    Tug Toy Road Train Member
    7,066
    73,928
    Jul 4, 2015
    Corn field
    $500 each for tie rod ends?!?!
    I’m outa touch…That seems like utter insanity? Are they greasable?
    mtclex and Big Road Skateboard Thank this.
  10. abyliks
    4,110
    9,662
    May 2, 2010
    ludlow MA
    Pretty sure I was around 4K with king pins and leaf springs in 2023 to do everything, which was all 1997 original,
    then of course it was all done again last year when I was hit head on, plus the steering box and pitman arm that time.
    honestly I would look at doing it all so it’s done and you only have to align it once, especially if you plan on keeping the truck
  11. mtclex
    37
    43
    Jul 6, 2022
    I was quoted 4k for Kingpins alone but after further inspection they’re still in good condition as is my leaf springs. I have a little wear on the outer and inner steer tire which indicates tie rod and possibly drag link. I’ll replace the tie rod, drag link and get an 3 axle alignment and go from there.
    Rideandrepair and Tug Toy Thank this.
