Owner Operators Required
Discussion in 'Canadian Truckers Forum' started by Prairie Boy, Dec 21, 2013.
  1. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    RATE STRUCTURE FOR THE 2013/14 WINTER SEASON.
    Rates to pull a Tridem Trailer will be $2.20 per mile loaded or empty.
    Should you pull more axles, the rate per mile will increase by $0.10 per mile for each additional axles over Tridem.
    Should you be required to String our loads or perform other billable services, the rate of compensation will be $110.00 per hour.
    Some projects have a clause stating that the first hour Unloading is at no charge. Others could also be all hourly.
    Some Projects will be flat rated on a per trip basis.
    Attached is a Contractor Agreement that we urge you to read.
    Come visit us at www.PioneerTruckLines.com
  3. 99pete379
    99pete379 Bobtail Member
    14
    Feb 14, 2013
    Hi do you have any runs from Calgary to Edmonton or around central alberta im looking to be close to home I live in reddeer. Thanks
  4. Prairie Boy
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    No we don't, sorry. Try Downtown's in Panoka.
  5. Cat sdp
    Cat sdp . .
    21,247
    75,731
    Apr 8, 2012
    Orion's Belt
    Don't seem to see the contractor agreement ?
    TexasTailTwister Thanks this.
  6. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
    Do you have any work from home positions, I'd rather not have to get up and put on pants?
  7. Prairie Boy
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    It's available by email.
  8. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Removed post as not pertaining to original topic.
  9. Ian55
    Ian55 Bobtail Member
    9
    Jan 10, 2014
    Does Pioneer still have a rig moving division?
  10. Prairie Boy
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    NO. Got rid of it about 6-7 years ago.
    Flint is getting out of rig moving at the end of March AND SO IS TransForce's rig movers like Howard's, Streepers, Kos, rebel etc. Goona be a pile of rig moving equipment at the Ritchie April sale.
  11. B77
    B77 Light Load Member
    189
    89
    Dec 16, 2010
    @pb; Are there to many rig move companies around or is it to hard to keep people?
