Paccar coolant issue
Discussion in 'Ask An Owner Operator' started by GYPSY65, Jan 23, 2024.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    I have a 2019 Paccar MX13 510hp
    coolant alarm keeps going on and when I have pulled over. It was full
    in the am I have added as little as a quart to 1/2 gallon but twice in the last week it puked coolant out when I stopped and had the engine idling
    I changed the sensor. No difference
    Replaced both radiator caps. No difference
    it will sometime stop dinging for hours or Evan a day or two and then ding for the next day or more with random breaks
    when I stop. It seems to at times stop dinging. Or I can let some pressure out of the reservoir and the level tops off
    as soon as I start driving. It starts up again
    seems to me the coolant is getting sucked down??
    it’s random enough that I don’t thinks it’s a wire
    It also seems if I’m south of I10 like Cali to Florida it stays off but north. It starts
    Nothing in the oil
    Nothing in the coolant and level goes up once I release pressure or it cools down overnight
    And I don’t see or notice any white smoke out the stack
  3. Diesel Dave
    9,651
    32,643
    Jan 20, 2010
    Hesperia, Ca.
    I replaced both sensors twice, one at the reservoir and the other on the block. At the end, it was hardness.
  4. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Liner dropped ?
    Their known to do this.
    Big Road Skateboard Thanks this.
  5. Espressolane
    18,667
    116,966
    When did you change the coolant last?
  6. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    Does the MX have a blow by tube? If so, stick a finger up it and see if it's nasty milky.
    Also look on the bottom of the filler cap.
  7. FLHT
    1,429
    2,546
    Aug 2, 2014
    Over flow tube out of coolant reservoir on drivers side of engine put in a jug of water.
    Start truck and rev
    Does it bubble ?
    If it does best find someone who Knows and Works on these motors.
    Parts on these motors are just to expensive to throw $$$ at.
    Good Luck.....
    Arctic_fox and GYPSY65 Thank this.
  8. 062
    062 Road Train Member
    6,327
    33,967
    Oct 20, 2013
  9. GYPSY65
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    Last summer
  10. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Sounds like you have the beginning of pressure in the cooling system. If its forcing coolant out the vent cap it is likely overpressure.
    Pressure test or suspect air compressor first especially if original. Head gasket failures are common on the compressor.
    Lets check this first.....
  11. GYPSY65
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    is the gasket a replaceable item or would it need a whole new unit?
    I “might” have figured it out
    Too early to tell yet
    But after cooling down and with the new caps in. I added about 1/2 gallon bottles f coolant
    200 miles this am and no dings yet and no coolant pushing out
    will know soon enough
    Goodysnap Thanks this.
