Paccar mx 2010 epa not using def
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trooper13, Feb 17, 2020.
  1. Trooper13
    Trooper13 Light Load Member
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
    I could use some help troubleshooting.
    Little red light on def gauge started blinking and throwing low def fluid warning on dash. Plenty of fluid in tank. Discovered this is likely because it's not using def fluid.
    Check fuses and harness connections, nothing evident there. About 650k on truck so i figure most components are original and likely due to be replaced. Start with what i can afford.
    Had already replaced def pump filter when i recently replaced dpf filter.
    Replaced doser injector because it had a good build up of def on it.
    Replaced def pump, it was easier to do in short time then the inside def tank screen which i finally was able to replace also.
    I could blow through all hoses, no restrictions or blockages.
    Truck was intermittently flashing the red light and progressing to the 5mph derate (first I've ever seen this truck do such a thing) had codes cleared after trying something else for repair each time. Replaced in tank screen last and only got about half a day before the derate.
    I have the short wiring harness and plan on throwing parts at it tomorrow. Seen some carton tops floating in the tank also do I'm going to just dump the def fluid to eliminate contaminated fluid. Aside from the main emissions harness I'm about out of ideas on what to do
  2. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,294
    Did you pressure wash the inside off the tank?
  3. Trooper13
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
    No. I did drop the screen and fought hard trying to get it back until i learned how to remove the gauge and take the tank all the way off the truck.
    Tank is mounted ps under front half of sleeper. Very difficult to work on it
  4. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,771
    Thanks Received:
    9,195
    Parts cannon can get really expensive. Take the truck to someone that knows the truck/engine and have it professionally diagnosed.
    But I'm that guy, so I guess that's easy for me to say.
    Without atleast seeing a detailed fault list we are all pissin' in the wind.
  5. Trooper13
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
    Not really much from the fault list. I'll try to share pictures of most recent when i get parked.
    Living in Casper Wyoming it's hard to find anyone able to legitimately diagnose. Have to basically burn a week to try to get into Kenworth. They help out allot by clearing codes and printing the faults at least. Hate going the parts changer way but I'm fairly limited to that considering income limitations and job demand
  6. Goodysnap
    Jul 12, 2017
    3,771
    Thanks Received:
    9,195
    When the Red DEF light is flashing on the gauge you have an active SCR fault occurring.
    Once we get that info progress can be made.
    spsauerland and Trooper13 Thank this.
  7. Trooper13
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
    Think i forgot to say earlier that it did completely stop using def. That's what's been triggering the derate. It was getting codes for the def pump pressure. Didn't see anything concerning scr at all
  8. Goodysnap
    Jul 12, 2017
    3,771
    Thanks Received:
    9,195
    If the DEF pump fails to prime, that would log an SCR related fault/derate.
  9. Trooper13
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
  10. Trooper13
    Apr 16, 2018
    62
    Thanks Received:
    29
    Casper, WY
    Had to pull the abs fuse to get truck parked back at yard. Almost all of the codes are from that. Really makes it more difficult if the real problem is hiding under the codes from defeating the 5mph derate
