Paccar MX13 Oil module replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Volvotech8080, Dec 6, 2018.
  1. Volvotech8080
    Volvotech8080 Bobtail Member
    10
    Dec 22, 2017
    Don't have access to service information for paccar. Have a friend with a mx13 that has an oil leak from the module, where it bolts to the block. Can anyone give me any info on torque specs or maybe a step by step guide on removing/installing the oil module (oil filter housing)
  3. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    stevez57305 Thanks this.
  4. JohnC123
    135
    66
    Jan 25, 2018
    Not much help torque wise but just a basic layout, I have hundreds of MX documents I want to share with the world because no one else will.
    stevez57305, RSB34 and Volvotech8080 Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,728
    9,060
    Jul 12, 2017
    Oil module bolt to block torque spec is 266 in lbs.
    What chassis are we working on?.....In most cases the cooling module will need to be removed to get it out from behind the framerail.
    stevez57305 and Volvotech8080 Thank this.
  6. Volvotech8080
    10
    Dec 22, 2017
  7. Goodysnap
    3,728
    9,060
    Jul 12, 2017
    That's gonna be EPA 17. I haven't had the pleasure in that chassis yet. Turbo will likely have to come off too. Torque value is the same.
    Volvotech8080 Thanks this.
  8. Volvotech8080
    10
    Dec 22, 2017
    Yes I had to move the turbo out of the way.
  9. JohnC123
    135
    66
    Jan 25, 2018
    Did you receive download?
  10. Volvotech8080
    10
    Dec 22, 2017
    No I didnt receive it. Do you want to try emailing it to me?
  11. kramershair
    kramershair Bobtail Member
    what mx docs do you have?mine is a 2011 mx13 epa10
