Paccar Regen
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kwayne88, Nov 11, 2020.
  1. kwayne88
    kwayne88 Light Load Member
    50
    15
    Jun 3, 2012
    Leesville, La.
    2018 Pete 579, MX13, 295k miles.
    Soot Level High screen pops up while driving. No passive regen.
    If unable to stop quickly and park regen get a check engine light with wrench and a derate.
    Been to dealer repair shop twice, still no passive regen.
    Any clue what to tell service dept. so they will know how to get the passive regen working?
  3. drive-away2020
    drive-away2020 Light Load Member
    68
    261
    Aug 17, 2020
    Check and change your sensors.
    IMAP sensor (intake manifold air pressure)
    EGR differential pressure sensor
    Maybe DPF differential pressure sensor
    Maybe Exhaust back pressure sensor
    if these sensors don’t read right and are carbon packed, it will throw all sorts of stuff off
    Edjahman Thanks this.
  4. kwayne88
    50
    15
    Jun 3, 2012
    Leesville, La.
    Thanks
    drive-away2020 Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You have an active fault code that is inhibiting passive regeneration. You need to get hooked up to troubleshoot the root cause fault.
    Get printouts, without them I cannot help.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Has DPF been cleaned?
  7. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    I have an MX13 EPA13 Paccar and I'm unable to locate a diagram for those sensors. I've done extensive Google searches and image searches.
    Do you know where I can get one?
    I want to pull mine and inspect them.
    Thank you.
