Paccar Water Pump Replacement Question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Proxy, Mar 19, 2019.
  1. Proxy
    Proxy Light Load Member
    165
    54
    Sep 3, 2018
    Good Afternoon! I am going to replace the water pump on an MX-13 in a couple days outside in a parking lot and want to sneak it out without draining down the whole system, does anybody happen to know how much coolant I need to drain in order to pop the pump off without making a huge mess? by the looks of it I will lose about 1/4 of radiator and the upper hose and housing above the water pump so I was guessing about 2-3 gallons? thanks!!
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    In what chasis and mileage? I usually just drain the whole cooling system. If over 400,000, I would change the coolant. Most Pete and KW are around the 12 gallon of coolant.
    Goodysnap and SAR Thank this.
  4. Proxy
    165
    54
    Sep 3, 2018
    2015 KW T680 with 475k, the coolant is new from a previous PM, I am more interested in preventing a mess than buying more coolant
  5. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Buy some buckets. You will have to drain more than 3/4 of the coolant when changing the w/p. Should be a drain fitting in lower radiator pipe, 5/16 Allen wrench if I recall correctly.
    Reason for edit: @Goodysnap gave correct size
    pushbroom Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,717
    9,024
    Jul 12, 2017
    Dont mess around with trying to drain it partway. Just dump it all out and refill it. You will make more of a mess with the system partially empty.
    The drain plug in the lower steel pipe is 5/16" or 8mm allen. The pipe thread size in the pipe is 3/8NPT. I ussually put in a brass draincock as the allen strips easy and is a PITA to work with.
    pushbroom and spsauerland Thank this.
  7. Goodysnap
    3,717
    9,024
    Jul 12, 2017
    To save yourself some headache.......there are holes in the belt tensioners to lock them open or in the loaded position. Line up the holes and slide an allen wrench in to lock it open. I think its 5/32" that fits the hole. Makes belt installation a breeze.
  8. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    When you buy your water pump, make sure you get just the cartridge. Also, large o-ring doesn't come with it.
  9. Proxy
    165
    54
    Sep 3, 2018
    thanks for all the reply's!!! will be tackling this tomorrow
