Paccar
Discussion in 'Kenworth Forum' started by Creolejo, Aug 24, 2016.
Page 1 of 4
In a reefer ......?????
Must be a big trailer? But the Paccar engine no matter what is bolted in is junk!
BoostedTeg Thanks this. -
You posted this in the Reefer section.
Paccar engine is great. Love it!!
KWPBMan Thanks this. -
What do you want to know about it? I have an MX13 in my 2015 T660, 185,000 miles, I will answer what questions I can.
That should be a Gen 1 MX-13. Problematic water pump seals and belt tensioners. The secondary fuel filter also doesn't like coming off once it's on there, though I've never seen one to the point where it stripped threads or anything of that sort. Same Holset aftertreatment system you'd get with a Cummins, although the connector on the dosing injector is different, as the location is very different. Davie 4 software is extremely Internet dependent, and you NEVER want to use it (especially for updates) with a shaky Internet connection. 12.9 liter engine, so not particularly a powerhouse. IIRC, not cruised as low as the Gen 2 engines... they have an exhaust brake, which I'm none too fond of. Seemed to work best with either the 25 micron Davco or that proprietary PACCAR fuel/water separator (although the latter seems to have issues with the water in fuel sensor taking a crap). Not a whole lot of places will have software for it, SCR, for some odd reason, considering its the same one Cummins uses, does't seem to have the tendency to crap out within the warranty period which it does with the Cummins. Dosing injectors typically need to be changed ~400k.. typical for a Holset system.
Junk, plagued with problems is what I heard
Coming from someone who drives a Volvo and does a lot off SHOUTING.
Just have a look at some off his other posts.
Too much drink or drugs?
You are so funny
Page 1 of 4
