Parked on ice
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Feb 21, 2024.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    I can't wait for this spring thaw! I've had enough of this cold white crap that does nothing but cause problems....
    Is there an effective trick to using rock salt to thaw the ice enough to regain traction? How long should it sit?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,970
    19,009
    Nov 1, 2010
    Burnsville, MN
    Where is this deep freeze you are talking about?
    This has been the mildest winter in far reaching history.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    When you stop your tires are hot, they will melt and sink into the ice.
    I usually would sit for 15 or 20 minutes. Then move the truck a door or so, then shut it down. And never set the trailer brakes in the winter. They may kick in later with the truck off and the air leaks down, but everything should be cold by then.
  5. upnorthwpg
    upnorthwpg Road Train Member
    1,829
    2,789
    Sep 23, 2011
    You don’t carry a tube of safety sand?
  6. bryan21384
    bryan21384 Road Train Member
    15,690
    34,179
    Sep 18, 2009
    Memphis, TN
    You'll need kitty litter under your drives. The salt can dissolve into the ice sometimes. The kitty litter will sit on top and help you gain traction. A couple of bags minimum, you're in business.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,476
    Mar 18, 2021
    St Malo mb
    Get 4 chains 16 inches long and 4 small ratchet straps attach one end of strap permanently to chain. Put chain over tire and ratchet strap through hole in rim attach to other end of chain and snug it up. Whichever tire spins it rips up ice under tire allowing you to move. I had those at a former company that used fuel mileage tires it worked great .
  8. Commuter69
    1,142
    635
    Jul 2, 2014
    The problem is that it's an equal opportunity problem, regardless of the amount; SOMEONE is going to overestimate their skills driving in it, their preparedness for it, OR underestimate the conditions and prove they CAN'T drive in it. It can be me as easy as it can be you, and I don't trust that ID10T who went right past me.....
    Prove me wrong.
  9. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    I carry chicken grit, it's like tiny rocks but they are kinda jagged. the stuff works miracles, way better than sand or floor dry. it will really bite the ice and your tires. gotten me in and out of places I never thought possible.
    available at your local farm store
  10. WesternPlains
    6,366
    57,263
    Sep 1, 2017
    Rapid City, SD
    Surely you jest….
    This winter has been tough. I put off driving into deep below zero. Stayed in Portland OR. They had only ten below wind chills from 50mph gusts. Other driver of ours ran into 37 below zero. He made it, barely. He said never again. Agreed…it’s too dangerous.
    Here's proof it actually does snow in Portland.
    On the parking. I had the front disk brakes on a Cascadia lock up. Surprised me. Helper with the tow told me. Fronts were locked while tow truck broke them free. They were just sliding. Brake line antifreeze is rubbing alcohol. Could use either.
  11. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,913
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Here in Minnesota its been in the 40s and 50s mostly since late Jan. It has only snowed once since Oct. Completely unheard of here (we have gotten a fair amout of rain). We usually have 2-3 weeks of below zero HIGHs in Jan/Feb...
    Mildest I have ever seen (Im 67). Moving to Florida in a couple of weeks to "escape the harsh winters" up here - heh.
