Parked regen ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Z800xp, Dec 21, 2020.
  1. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    Does the truck need to be up to temperature to do a parked seven ?
  3. AModelCat
    164,498
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yes, I think on a Detroit coolant temperature has to be at least 165 degrees. Or close to it.
    Trucker61016 Thanks this.
  5. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    You need the engine at operating temp and the exhaust as well (doc to be exact)
  6. JRBES
    JRBES Bobtail Member
    17
    4
    Jun 22, 2015
    truck needs to be at temp like they said. Then the DOC has to reach a certain temp to open Fuel injector behind turbo to begin cleaning process!! Remove that injector ensure is clean if your having trouble.
  7. DJMech
    DJMech Bobtail Member
    20
    12
    Jan 23, 2021
    **149 Degree minimum**
    uncleal13 Thanks this.
