Part-time need for ELD
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Clreifsc, Jan 4, 2019.
  1. Clreifsc
    Clreifsc Bobtail Member
    We farm and typically haul grain but have started hauling building trusses in the off season. The more we have started to do it, the closer we are to going outside of our 100 mile radius more than 8 times a month. Is there an ELD product that allows us to pay month to month for the months when we need it? I'm finding most are a monthly subscription but you are required to pay for a whole year. Thanks in advance.
  3. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I think keep trucking is month to month...
  4. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I just saw this one too at truck stop.. you might give it a try 20190104_192900.jpg
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    You will likely be better off buying a Garmin, or one of the other ones that are an outright buy. No monthly fee.
    I believe the Garmin is $350, one time and no more fees.
  6. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Actually the best person to ask is @Dieselboss . I just tagged him so maybe he can recommend a unit.
    Dieselboss Thanks this.
  7. Ridgeline
    22,708
    122,474
    Farm?
    No authority?
    Right?
    I would think that you can just use paper and when you reach the log retention time, you don't have to prove that you were running before that time.
    I was told being a farm, you don't have the same record keeping requirements as an authority, so you don't have to retain the logs for six months.
    Oh and it is 150 air mile radius not 100 miles.
  8. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    $250 and available at truck stops. No monthly fees.
    ZVar Thanks this.
  9. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    He's not running ag, he's running a commercial business. As such the time ard exemption is 100 air miles / 12 hour days.
    Well unless he's running non-cdl under 26,001 lbs.
    Accidental Trucker and dan31186 Thank this.
  10. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    I'm reading like @ZVar is. Looks like you probably run Agriculture rules most of the time but are now starting to run non-Ag as well.
    (to recap) If you are running Ag rules, you can run a 150 mile radius without ELD and need ELD only outside of that "bubble area" (for lack of a better term.) There are (of course) expanded definitions of all that Ag stuff and here is a great guide if you want: https://www.fmcsa.dot.gov/sites/fmc...ice/elds/81736/eld-hos-ag-exemptions-v3-1.pdf
    If you are hauling trusses, then you probably DO FALL under the "100-mile" rule (depending on weight) as you stated and not the 150 on those runs. If you go more than 8 times in a 30-day block outside of your TWO BUBBLES (one is 100 mile stuff and the other is your 150 miles stuff) then you do need ELD as you correctly surmised.
    There are very few ELDs that do not have a monthly fee. It is a risky business model AND at least two of them who tried that model have closed their doors as a result so far (One20 and ZED.) However, if you do want to go that direction then I will give you three of them to check here: Garmin, VDO Roadlog, and Blue Ink (BIT.) Each of those 3 have and upside and a downside, but those 3 still appear to be supporting their "no fee" business model at the time of this writing. Keep Truckin was mentioned earlier: they do have a monthly fee, except they have you pay it yearly.
    Hope that helps you and maybe some lurkers too.
    (Disclaimer: DieselBoss, Inc has ZERO business relationship with any of the companies mentioned in this post and makes no opinions one over the other.)
    Accidental Trucker and 25(2)+2 Thank this.
  11. Clreifsc
    Yes, that is correct, thank you very much for the help. When you said 100 mile bubble (depending on weight)... what is it that depends on the weight?
