Per mile or load %
Discussion in 'Ask An Owner Operator' started by JORTRUCK, Apr 6, 2017.
  1. JORTRUCK
    JORTRUCK Light Load Member
    232
    31
    Mar 9, 2017
    Which one better when you own tractor only
    And running under company authority
    To get pay per mile or load % and why ?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You will have to be able to see how much the loads are billed to shipper to find out the real amount of % you will see, if the mi. rate is more then go pay by mi.
  4. rollin coal
    rollin coal Road Train Member
    13,590
    27,951
    Mar 29, 2008
    TN
    What trailer are you wanting to pull? It really wont make any difference either choice if all you want to do is drive and allow someone else to load your truck.
    If you're a go getter, make it happen kind of driver then percentage is the best choice. As long as you aren't leased at some shady skimming, scammer company.
  5. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    There is no relevance to either pay scheme, what matters is how much the pay is in relation to expenses.
    A 2 dollar per mile rate is better than flat rate for the same load that works out to 1 dollar per mile.
    A flat rate per load that works out to 2 dollars per mile is better than a per mile rate of 1 dollar per mile on the same load.
    Most big shippers end up at about the same rate in actual dollars regardless of how they compute it, and that amount is not enough to the truck owner.
    You will do better acquiring your own authority and using load boards to stay loaded and running in the regions that are profitable and that you prefer. With the shortage of trucks today there is just no reason to lease on with one carrier and try to live on the scraps they toss you, they are absolutely not worth the percentage of your money that they take.
  6. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    You "can" do better, others don't. There's nothing wrong with leasing to a percentage based carrier. Especially when they have freight in your area on lock with direct customers and keep you moving with drop/hook loads. In certain areas you're getting the scraps.
  7. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    Of course "others don't", trucking is a business and everyone is not cut out to run a business.
    My post was not meant to convey that everyone has what it takes to operate independently and prosper, my post was meant to convey that those who do genuinely want to run their truck as a business will do better by not giving away their profit to other businesses for tasks that any competent business person can do themselves.
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Type of freight is why Im choosing to lease on with my current employer when I get my own truck. They have direct shippers/receivers and frankly I cant afford $100,000+ chemical tanker and $100,000+ pneumatic tanker trailers. Lol
    I will be a % contractor too.
  9. rollin coal
    13,590
    27,951
    Mar 29, 2008
    TN
    I genuinely run my truck as a business leased on at a company on percentage. With much lower costs than most single truck independents out here. When it comes down to the net I doubt there is really a huge difference.
    LumbraX Thanks this.
  10. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    Sounds like your a tanker yanker. I've always ran %. It basically evens out to about between $1.75-2.00/mile of you include the fsc. I don't know any companies paying $1.50/mile + fsc, exact Trimac.
    Roberts450 Thanks this.
