Pete 387 Question
Discussion in 'May Trucking' started by Dozzer6, Sep 28, 2011.
  1. Dozzer6
    Dozzer6 Light Load Member
    252
    22
    Jun 30, 2011
    Vancouver, Washington
    How can I change the tempature readout on the drivers mirror to be farenhight instead of celcius. Its a 2008.
    Dozzer
  3. Biscuit75
    Biscuit75 Road Train Member
    I found a few different ways listed online....
    1.)Remove the "flat glass assembly" from the "mirror head". Then on the back of this assembly there is a small "recessed gray button". Pressing and releasing this button will toggle the display through Celsius, Off and Fahrenheit in that order.
    2.)Can be done by the driver without getting out of the seat. To start, you turn the key to provide electric power to the truck. Then you wait at least 5 seconds for the mirror to stabilize.
    Then cover the display area of the mirror to block out all light for at least 5 seconds following which you uncover the area for at least five seconds.
    You repeat this 2 more times for a total 3.
    Each time you go through this turning on the electric power and covering/uncovering the display/display light sensor 3 times, you change the display status once. The display status goes from off to Fahrenheit or Fahrenheit to Celsius or Celcius to off each time you go through this sequence.
    3.)Pushing the odometer button repeatedly until it changes the temp setting.
    Hopefully one of these works...
    Dozzer6 Thanks this.
  4. Dozzer6
    252
    22
    Jun 30, 2011
    I looks up the user manual online and it didn't seem to tell me anything so I appreciate the feedback. I will try these if I ever het it out of the shop.
    Dozzer
  5. Biscuit75
    If it's in the shop they could prob change it in the computer really easily.
