Pete sub location in bunk?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Toyman, Jan 1, 2016.
  1. Toyman
    Toyman Light Load Member
    61
    23
    Mar 28, 2009
    Central MO.
    Hey guys & gals Happy New Year!
    Well my concert class head unit finally died after 1 million plus miles & was replaced with a Panasonic aftermarket unit from Peterbilt that is rated 50W x 4 with 16W x 4 RMS. I know it has an amp in the overhead console (have seen it) & was told it had a sub in the bunk. With the new head unit i gave up some sound quality but got an aux input & backlit dispay again. I have lost some but not all of my super strong bass from the sleeper now & wanted to tear into it & make sure it is still firing. The new unit plugged in so no cutting/ splicing was done. Any idea where to start? I've looked under the bunk & don't see any dead space. Thanks for your help.
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I had a 386 with the sub under the bunk.
    The enclosure was at the front driver side middle of the front of the bunk.
    If I remember correctly its not a very large speaker. 8" speaker inside a simple enclosure. Sounded ok compared to other factory truck systems. Nothing to really write home about. Definitely not the pounding bass you would find from 12" - 15" sub boxes powered by 1500 watt amps.
    Hurst
  4. Toyman
    61
    23
    Mar 28, 2009
    Central MO.
    Thanks Hurst. When i get back to my truck on monday will take a better look. I know before it would make things rattle & shake if i cranked up the lows & now just doesnt have that thump.
  5. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Most aftermarket head units have a separate RCA output specifically for subs. The harness adapter generally does not feed the sub. So chances are your sub is not working at all.
    I went through this with my Silverado. It came with the Bose system and had a sub inside the console between the seats. I bought an aftermarket DVD/Stereo set up and had to run a sub line to the amp for the sub. The harness that came with the stereo did not feed the sub.
    Hurst
