Peterbilt 387 reverse light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by David387, Nov 25, 2019.
  1. David387
    David387 Bobtail Member
    13
    2011 peterbilt 387
    Eaton fuller 10 speed automatic transmission
    Recently had clutch changed and now dont have any reverse lights
    I changed out the reverse light switch on top of transmission. Still nothing.
    I have no power anywhere in wiring from switch back. Changed out the switch 3 times and still nothing.
    I’m at a loss at this point.
    Any ideas
  3. Goodysnap
    Goodysnap Road Train Member
    3,765
    9,179
    Jul 12, 2017
    Maybe the key was accidentally turned on during the clutch change and the wiring was shorted , blew the fuse. You should have power to one side of the switch Key on. Check all fuses. If you need help tracing upstream please post VIN.
    spsauerland and pushbroom Thank this.
  4. David387
    13
    Checked and double checked fuses. Only fuse I can find is in passenger side box that says back lights if I remember correctly. Fuse looked good but changed anyway. That’s what lead me to think it was switch on transmission.
    vin 1XP7D49X7BD125923
  5. Goodysnap
    3,765
    9,179
    Jul 12, 2017
    Hopefully this will help.
    I would start by giving the wiring a shakedown and pull test in the area of the last repair. Most wiring issues are found outside the cab.
    pushbroom and spsauerland Thank this.
  6. rmankid
    rmankid Bobtail Member
    7
    15
    Mar 21, 2016
    I found a wiring diagram that shows the reverse lamps being powered through a relay. Both the coil and load side of the relay are powered through a 15 amp fuse. The coil side of the relay is tripped by an output from the transmission, this would have to provide a ground for the coil to switch. I'd start by searching for a "reverse lamp relay" and sort out what you have at that location. Hope this helps.
