Peterbilt coolant loss
Discussion in 'Ask An Owner Operator' started by acisner6, Jun 11, 2021.
  1. acisner6
    acisner6 Bobtail Member
    May 10, 2016
    I have a 2014 peterbilt cummins engine 900k miles
    It suddenly started losing coolant it went from not losing anything to losing about a gallon a day. No leaks under truck nothing coming from exhaust that I can see. Oil from dipstick looks good but I took off oil fill cap with engine running there’s a lot steam coming out. Anybody have this happen or have an idea what it might be.
    77fib77 and feldsforever Thank this.
  3. HillbillyDeluxeTruck
    5,952
    30,449
    Mar 3, 2013
    San Antone
    EGR coolers are known culprits. A sunk liner can be another cause. Cracked head yet another.
  4. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Hopefully it’s the egr cooler. Not a pinhole in a piston liner. Must be going out the exhaust, if it’s not in the oil, or on the ground. Only other place I know of would be a transmission cooler. If you have the coolant type. It could be going into the transmission. Usually it’s just a small amount. I doubt it’s that. Easy to check though. Take the fill plug out, see if it’s way overfilled.
    77fib77 and spindrift Thank this.
  5. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    I recently had the same issue. I wasn't losing that much. But mine was leaking from one of the 3/8" heater hose that supplies coolant to the DEF dose. It was dripping on to the exhaust so it never left a puddle. The only indication was the hose collected some dust. On the 579 w/sleeper there is two 6" long hoses collected to the sleeper hvac.
    feldsforever and Rideandrepair Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Have EGR cooler checked
  7. B-unit trucking
    B-unit trucking Bobtail Member
    I’m having the same problem right now… Did you figure it out?
  8. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    If you pull the oil cap off and lotsa smoke comes out. It's time for a rebuilt.
    If you try to add oil with it running. It'll literally blow the jug off.
    I was using 4 gallons coolant a day and a fresh oil change only lasted a week before oil pressure went dead.
    Phoenix Heavy Haul and 77fib77 Thank this.
  9. 77fib77
    77fib77 Road Train Member
    11,639
    76,731
    Jul 7, 2010
    St Louis
    Take off the EGR pipe and see if the pipe goting into the intake manifold is fouled up?????
    If it's EGR. The oil pressure is higher than the coolant, so it should push into the radiator???
    Are these right?
    Grek8888 Thanks this.
  10. snowwy
    20,612
    13,333
    Jul 6, 2009
    I'd think if it pushed in to the coolant. You'd see steam and coolant loss out the cap. Maybe even blow the reservoir up. From too much pressure.
    I installed a new cap cuz I thought it was bad. It was only a marginal improvement of coolant loss.
