Peterbilt engine fan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2006gmcdmax, Apr 30, 2023.
  1. 2006gmcdmax
    2006gmcdmax Light Load Member
    67
    26
    Jan 31, 2018
    I have a 07 357 peterbilt factory dump truck with a c11 and an Allison 4500 in it. The fan comes on and goes off with the engine fan switch and also with the air conditioner as it supposed to. When I put the truck in gear soon as you hit drive the engine fan comes on soon as you put it in neutral it shuts off. Only light I have on is a abs light. Any ideas would be great thank you.
  3. Goodysnap
    Goodysnap Road Train Member
    3,760
    9,165
    Jul 12, 2017
    Wiggle test the connection at the high side Fan cycle switch for the A/C. Suspect loose pin connection to switch or open copper inside the insulation.
    Even tho the AC is not in use, the switch is normally closed. Open circuit will turn fan on.
    singlescrewshaker, Oxbow and Bean Jr. Thank this.
  4. 2006gmcdmax
    67
    26
    Jan 31, 2018
    It literally only does it when you put the truck in gear soon as you hit drive or reverse it comes on you hear the solenoid on the fire wall engage it
    Soon as you hit neutral it shuts right off
    I just put a condenser coil on it it calls for 2.50 pounds of Freon so basically 3.33 cans
  5. Goodysnap
    3,760
    9,165
    Jul 12, 2017
    Engine is moving when you put it in gear.
    Hook up and monitor the engine Fan switch inputs and see which one is commanding the fan on.
    My previous suggestion is most common failure.
    pushbroom and Oxbow Thank this.
  6. 2006gmcdmax
    67
    26
    Jan 31, 2018
    Yessir I appreciate it hopefully tomorrow I can get it where someone has cat et and they can hook to it
